Best Grade of Gasoline
crlande
Year and Model: 240DL;850;S70
Been thanked: 36 times
Re: Best Grade of Gasoline
Post by crlande »
I think oragex hit on a bigger issue. While at a gas place that my work uses I heard the delivery driver ask where to put the rest of the 87 since the those tanks were now full. Owner said to put the rest in the other tanks! My eyes went wide open as I looked at the owner.
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
abscate wrote: 02 Mar 2018, 21:53 Remember you have to be careful to sort out if the manual is referring to US or EU octane, read the fine print
Hi,
What is the conversion factor?
Thanks.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
abscate wrote: 03 Mar 2018, 03:24 Not too many differences but just remember to never mix Shell And Mobil products..
Huh? I use Mobil 1 oil and often pump Shell gas. What is suppose to be the problem with that?
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
rspi wrote: 03 Mar 2018, 18:53
You missed abscate's subtle joke here. Nothing wrong with Shell gas and Mobil oil used at the same time. :lol: June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
rspi
Post by rspi »
On this video, at 2:30, you can see what my intake valves look like after 362,000 miles.
Has thanked: 1502 times
Been thanked: 3817 times
MrAl wrote: 03 Mar 2018, 05:31
Hi,
Thanks.
Our87 octane gas is the same as 91 octane in Europe..
Shell plus Mobil equals Schmell,.....its an old Cartalk joke...I'm merely the messenger
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
Good schmell or bad schmell?
Switched from Stewarts to a different source recently - ended up with much better performance. Now if I can just remember where I filled up, I'd be all set. Time to check my receipts...
crlande
Post by crlande »
Next time you see the big rig filling the tanks at your local gas place ask the driver. Most haulers are local that all go to the same fuel depot, fill up and add the brand name fuel's required additives. Unbranded stations get the same gas minus the additives and even that can get muddied into the drivers delivery route stops for that day. A large chain gas/mini mart in my area reportedly uses BP but will negotiate with Exxon and Shell when needed. The unbranded gas station owner is required to buy minimum volumes which would explain why I saw the driver putting 87 into the 89 and 91 tanks. The oil companies spend millions of dollars advertising their additives. The Feds require all gas to meet certain standards without the additives. Best advice, now your car, your gas station.
WCM - the 93 octane at the Stewarts is ethanol free - and once the kids are older and are eating you out of house and home the loyalty program at PC means I pay about $1.50 to 2 bucks a gallon for 93 octane. I might actually use it with my turbo hooked up correctly
I really should sell this car to someone who wants a HPT - i realize I never rev over 3000 the way I drive. Im calling it July driving - Im always going to be following June.
Just for giggles I took it down to Route 32 to get burgers last night and took it up to 4000-5000 - the power up there is amazing.
wizechatmgr
Turns out it was a different Stewarts - with newer tanks & dispensers...
I've also filled up at the occasional Pilot/Flying J. Unfortunately I believe that to be ethanol diluted.
**Back to making programmers shed tears by rejecting bad code**
