1999 V70 Codes, Dash Lights, and Oil Smell
AaronsVolvo
Year and Model: 1999 V70
Has thanked: 11 times
Post by AaronsVolvo »
I’ll order it now, thank you!
I’ll hold off on parts for now.
Nope, Atlanta....
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
While your waiting, compression tests, glove test, pull plugs check condition ... ect, in other words get a profile of the general health of the engine.
Active
Past
Has thanked: 1611 times
Been thanked: 4074 times
On my 1999...
Front abs sensors. One M6 10mm head bolt vertical
Plan on removing the wheel to get the sensor out. Possible with wheel on but gnarly in there
On rear , one horizontal torx. My sensor was really stuck. Destroyed it getting it out. Easy to remove with wheel in if it isn’t frozen but the harness has to be fished up into trunk area. On the 1999 the two ABS sensors come as a one piece loom with two sensors connected.
I’ve soldered the wires about 6 times but if there is any flex at the break the repair doesn’t last , the longest I made it was 3 years.
I’m not sure the sensors fault unless they get overheated and melt. Inspect the wires and I bet there is a break.
You lose ABS and cruise control if a sensor faults or wire breaks , I think in some engine systems it can cause limp transmission mode too?
I used Delphi aftermarket for my last one ( don’t hate me June)
Recent thread with pictures under part numbers too
AaronsVolvo
My ABS and cruise control both work.
Todays project-heater core and O rings have been replaced!
Now waiting for the mailman to bring me the lift gate struts, shop manuel and Vida+dice.
Ill be doing a bit of cleaning in the front seats while I wait....there may be a little bit of antifreeze on the drivers side *cough*
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
Toss a 13 gallon trash bag under the core as you undo the pipes to it.
Drain the coolant from the radiator first - makes a lot less mess.
If all else fails, replace the bag with a shopvac.
Don't forget the heater hoses & radiator hoses are likely from '98, unless you've already replaced them.
2023 Lexus RZ450e -66k
RickHaleParker
I suggest you get the RePack version of Vida. It can be used in a updated Windows 7 environment or a Windows 10 environment. Good chance your need the 2099 patch which is on page 1. The RePack is on page 6. Vida Repack and 2099 Patch
If you have any questions about Vida-DiCE, ask then in the Vida, Vadis, DiCE form.
Active
Past
AaronsVolvo
Thanks for the advice Wiz
Okay thats good to know Rick, my Vida should be here next Tuesday so I still have a bit of waiting.
RickHaleParker
The online website that allows you to download a copy of desired car user manuals without any charges.
Owners manuals does not do any good. He needs REPAIR and SERVICE manuals.
Workshop manuals cannot be down loaded ... This is click bait.
Hate it when leaches try to ride on other's work.
Active
Past
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
RickHaleParker wrote: 06 Mar 2018, 20:51 The online website that allows you to download a copy of desired car user manuals without any charges.
If there were actual repair manuals floating around, I would jump on that in a heartbeat. The FSM for my 4runner has been a godsend.
Use the report button to flag the trolls please, ladies and gentlemen. This one has been dealt with already
