is it possible one or more of the ignition coils to fail (Check Engine Light code Po302)due to too high voltage to spark plug---could indicate excessive spark plug gap.
The old spark plugs gap was 052----- I think should be around 030-all wires ok
I the faulty coil and all the spark plugs and fixed problem
xc 70 2005 118k miles
ignition coils has failed due to spark plug large gap
- Been thanked: 472 times
No,
Coils fail b/c of internal short (the insulation of the copper windings fails), especially with heat. Get used coils on ebay for cheap.
- RickHaleParker
- Been thanked: 958 times
Yes, excess gap is one of the more common root causes for coil failure.
Excessive gap can cause an ignition coil to overheat. More of the energy from the collapsing electromagnetic field gets converted to heat rather then discharged as electrical energy.
- Has thanked: 1505 times
- Been thanked: 3818 times
I would guess your plugs failed with Wear and your coil failed on time. Your four other coils are probably arguing with the Grim Reaper, too. At very least carry a good spare ( shameless plug
but if it’s a daily driver do the other four next payday,
Ive got some cheap spares in the parts for sale Forum as do others, or Pnp.
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 64 times
- Been thanked: 69 times
A shameless plug for a coil.......
Gotta conclude the unadjustable "tri-tode" sparky-poos in non-turbos, when replaced on schedule, eliminate that failure point.
If you ever start liking my humor, see your therapist, quickly.
Man went to a doctor, gave him six months to live, couldnt pay his bill...
I though that one was
A baby seal walks into a bar
what will you have?
anything but Canadian Club
what will you have?
- 3648 Views
- 2513 Views
Last post by Roger_850T
