So we finally pulled the head off this car that’s been sitting for a while. Is the white crystally lookin stuff from the coolant when the HG gave up? Or what is it? What’s the best way to clean it up to prep for the new head?
Thanks you for your help.
Stephan
98 V70 glt headgasket
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
- Has thanked: 311 times
- Been thanked: 817 times
Now that provides some motivation to keep changing the coolant regularly.
stephansvolvo
So is it toast or cleanable/repairable?
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
stephansvolvo
Not that it matters. I titled this as V70 this is actually an S70.
I picked it up a year and half ago knowing he HG had given up. I had to put the project on hold because I figured my wife was right about paying he mortgage first.
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
My guess would be that the PO put some "head gasket fix in a bottle" in it. I've pulled the head on many, many Volvo's that I doubt had coolant changes that had NONE of that stuff.
stephansvolvo
It definitely was not taken care of. The plug wires were literally melting in my hands. The plugs hadn’t been changed in who knows, probably never yet the timing belt was done in nov 2014.rspi wrote: 08 Mar 2018, 09:13 My guess would be that the PO put some "head gasket fix in a bottle" in it. I've pulled the head on many, many Volvo's that I doubt had coolant changes that had NONE of that stuff.
Either way, Robert, is there a best way to clean this stuff up? I did the head on my v70 a few years ago and it didn’t look like this either, it was pretty well maintained. So this corrosion is new to me.
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- rspi
Contact rspi..
If the car was overheated until it shut down, all kinds of gunk in there, melted parts on it, I'd replace the engine, turbo and all.
I would go for another engine, too.
- Has thanked: 2203 times
Hate to say it but agree with the other guys on replacing the whole engine. If that is a stop leak type product it can get everywhere like the radiator, water pump, heater core and turbo pipes to name but a few places. The only way to not do that is to pull the whole motor, strip it down and have the engine acid cleaned to get the crap out. Initially I thought it might have been some cheapskate using tap water from a very hard water area in the coolant instead of de-ionised water, but looking at it I don't think that is it.
Good luck whatever you do.
- 9 Replies
- 2293 Views
Last post by jonesg
- 285 Views
Last post by erikv11
- 703 Views
Last post by rspi
- 282 Views
Last post by songzunhuang
- 1597 Views
Last post by wizechatmgr
