Ball joint install difficult,can't keep it straight
olpossum
Year and Model: 03 V70, 99S70
Post by olpossum »
This is a 2003 V70 with 130k miles or so. Inspection time in MO,front end having looseness & noises,bought many parts, getting it all back together,but the 2nd balljoint won't go into its knuckle - it keeps tilting over in the direction of the bolt holes when I try to tighten it down,and I'm afraid to use too much force trying to straighten it,don't think the ears on the joint will bend,but something may strip.The first one went so easily I don't remember how I did it. Tried the freezer,not cold enough. Anybody got any ideas? Yes, I have searched.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
If the bj is Lemforder, it should go quite nicely in there. Other brands, beside not being necessarily durable, have not be machined to the exact specs which are very tight for this fitting.
The freezer would take a 24h. Is the hole into the knuckle pristine clean? I've put a steel sponge wire on my electric drill and cleaned the hole big time, then put inside a smear of CV joint high pressure grease. Then I guess you are using a piece of pipe or a large socket to tap the bj inside, careful not to kink the rubber boot. @19:00
olpossum
Post by olpossum »
Yeah, it is. I've washed it out&cleaned the joint well, too. I'll try the 24-hour freezer,prob. put the knuckle in the oven.Pilot light makes it nice & warm in there. Thanks for the helpful input.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
oragex wrote: 09 Mar 2018, 15:50 If the bj is Lemforder, it should go quite nicely in there. Other brands, beside not being necessarily durable, have not be machined to the exact specs which are very tight for this fitting.
Your videos are very good.!
jonesg
Post by jonesg »
olpossum wrote: 09 Mar 2018, 16:52 Yeah, it is. I've washed it out&cleaned the joint well, too. I'll try the 24-hour freezer,prob. put the knuckle in the oven.Pilot light makes it nice & warm in there. Thanks for the helpful input.
I gave up and took a grinder to mine.
Took most of the knurling off and still had to force it in. No problem 1 yr later.
Pretty sure I've read there are 2 sizes.
Better too big than too small.
velorider
Year and Model: 2005 S60 T5
Has thanked: 2 times
Been thanked: 27 times
Post by velorider »
Freezer and a home made 2" PVC driver. Get some extra long bolts for a guide. Use the extra long bolts to hand tighten the ball joint to the knuckle. Then hammer away. Leave the protective plastic boot.
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
The ears on the Lemforder can still bend a little in my experience, maybe a millimeter so that the joint doesn't seat fully into the knuckle. Once you get it most of the way in by tightening the bolts I found it pretty easy to seat it the rest of the way in with a socket extension positioned at various points around the outside and a small hammer being careful not to pinch the boot. Then finish tightening/torque the bolts.
If you're having problems getting it to start in straight then there's an issue with fitment: wrong P/N joint, poorly made aftermarket joint, or oxidized aluminum effectively making the hole smaller (use fine grit sandpaper).
oragex
Post by oragex »
jonesg wrote: 09 Mar 2018, 17:08
There are two types of control arms, yours - alloy one - and the later which was fully steel. Not impossible they made two sizes of ball joint indeed.
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
I recently replaced the ball joints and had the same problem, couldn't keep either side straight while driving them in. The other problem is a ridge developed inside the aluminum knuckle from the ball joint not going in straight and this made things much worse. I used Mevotech ball joints and they were very tight. This is the 3rd set of ball joints replaced and the first two times I didn't have this problem.
What I ended up doing was smoothing down the ridge inside knuckle opening using a small Dremel sanding wheel drum and then use an air hammer with a dulled chisel tip and very low air setting to adjust the ball joint as I drove in it with hammer and 2 inch pipe and cap. The air hammer allowed me to adjust (drive down the high side) the the ball joint if wasn't going in straight and this really helped out. After evening things out I'd continue to drive the ball joint in with the hammer and pipe. This type of adjustment could also be done with a punch and hammer. It was also helpful to pull up the boot to prevent it from being damaged and also to provide better striking points for adjustments. If there's a next time I'll stick with the Lemforder brand ball joint.
dcm0123
Year and Model: S80 2000
Post by dcm0123 »
I had problems installing a Volvo OEM ball joint on the side which had a lot of corrosion. Not on the other side which did not. Suggest you use the use the Dremel sander or a rotary wire brush, lot of grease and air hammer on the pipe cap as noted above. A similar approach worked for me.
