XC90 Unidentified Coolant Leak
MisterWooley
Year and Model: XC90 2004
Post by MisterWooley »
XC90 2004 D5 2.4 diesel 163 bhp (RHD UK) 198,000 miles
About 3 months ago I started to see a small coolant loss. Maybe due to slight weeping from top up bottle beginning to crack but nothing visible anywhere in/under engine, or inside car floor pans .
That has changed quite suddenly. Today in the morning I topped up the coolant level drove into town, 6 miles, drove home 6 miles but on the way home got the coolant low warning. So thats a loss of about 1 pint in 12 miles, getting serious.
Most of the time no dripping underneath but sometime yes, the from left side of the engine block is wet. I'm at a loss as to where the leak is. The thermostat housing seems to be dry so not dripping down from there. I did wonder if the leak is from the water pump but don't see how that would wet the front of the block. Any hints please?
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
Pressure test the system. In the US many auto parts stores will loan the pressure tester to you for free.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Put some trace dye in the coolant then, with a UV light trace the leak back to the source.
Active
Past
