As the title states.
The wife's 855 is going to get it's engine swapped (Slight HG leak and engine getting tired at 275K miles). The replacement is sitting on a skid weighing just about 325#.
The plan was to drive the wagon to work and just load it up in the back to get it home. I would think it should be OK, as I bet many get loaded down with MUCH more weight (passengers and cargo).
Removing it will just involve the engine hoist.
How much weight do you load up your wagons with?
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 335 times
- Has thanked: 292 times
- Been thanked: 765 times
I have read many reports of people transporting replacement engines in the back of a P80 wagon.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
DrJammer
- Year and Model: 2000 V70XC - 195k
I put WAY more than 325 pounds of wood rounds into my wagon.
Ex-Volvos
2004 v70 N/A - traded in at 75k
2008 S60 - leased
1998 S70 T5 - might still have her if I knew about this forum when I owned it
2008 S60 - leased
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
I've fitted my P2 with reinforced rear springs to keep it level when loaded to the limit and with bikes on the hitch. It's a great upgrade both for looks (doesn't look like you're carrying too much) and handling
- Has thanked: 1847 times
- Been thanked: 1710 times
What you may want to consider is that the trunk floor is not actually the floor but some plywood and carpet. So you might need to add some additional plywood or such to prevent a point load going right through the floor.
- Has thanked: 1505 times
- Been thanked: 3817 times
wcm and I celebrate harvesting used engine oil with ice cream sundaes - we are way heavier than a steenking Volvo engine.
- Rattnalle
While I agree that it's something to keep in mind and easy to do something about it's not that thin and I think the wood floor might actually take a point load better than the sheet metal beneath it.
- Chuck W
The engine is on a skid, so no worries there.
- 31 Replies
- 4500 Views
Last post by callahanoffroad
- 30 Replies
- 4184 Views
Last post by DennisCA
