Didn’t get my coolant hoses done with some of my car time going to inspecting my lower right mount, so I settled on swapping out my TCV and the lines. The lines were in terrible shape.
That one off the compressor was a real pain but definitely glad I did it as it was in the worst shape of all.
I can’t really test out the new TCV as I have to drive like a little old lady until I get my motor mount in the mail, throttle response seems a touch better but that might just be in my head not sure
- ZionXIX
- Has thanked: 65 times
- Been thanked: 194 times
I dont know but its worth calling him to find out.j-dawg wrote: ↑11 Mar 2018, 11:59Do you know if he's willing to part it out? I'd be interested in some of the bits and blobs off of it, local enough to make the trip.ZionXIX wrote: ↑10 Mar 2018, 05:01 If anyone is interested my Volvo mechanic Mark is selling a C70 project car in Dallas. It looks like the body panels are in perfect shape. https://dallas.craigslist.org/dal/pts/6503299546.html
- jtp
- Year and Model: 99 v70R
- Has thanked: 11 times
- Been thanked: 10 times
Tried to change out my rear diff fluid but the drain plug is seized. Sprayed it with PB blaster and will try again in a day or two.
Glad I got under there as I noticed leaks at axle seals on both sides of the diff. Passenger side is leaking bad. D side just weeping.
Control arms are really badly rusted from the bottom and Nivomats aren’t leaking but they are rusting out as well.
It never ends...
It never ends...
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
Almost 155K Miles
98 S70NA (sold)
- Has thanked: 1505 times
- Been thanked: 3818 times
Careful application of heat should free that up, if it can be done safely
- Has thanked: 304 times
- Been thanked: 517 times
Repaired some more wires with new terminals... this time for the ECT sensor. Maybe my little hiccup will be resolved finally. The resistance was too high for my liking between the ECT connector and the ECU, and it fluctuated pretty severely when I moved the wire. Now it's solid.
Always check your terminals! Old, corroded terminals cause big problems.
- ZionXIX
For $500 you could buy it and part it out and get your headlights
That's what I would do!
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
If a Volvo mechanic can't find $500 of parts in this thing to use on his customer's cars, I'd bet there's $0 worth of parts past the headlights. If the headlights and corners are a ~$300-value set and scrap value is $300, I'm barely past breaking even. Throw in 200+ miles round-trip to Mesquite and I'll just buy them from eBay if I really want them.
