Hi wonderful Volvo folks,
I have a 2003 Volvo v70, with two little ones who like to take car naps. When we are back home I hate to get out of the car because the stupid door chime starts going off which will wake them up. I did a bunch of research and haven't found a way to disable the chime on an 03 V70. Is there a relay to pull? I'd even clip a wire if it was easy to access. All the other guides and posts are for previous generation cars. I even looked through service diagrams with no luck.
Let me know if anyone knows how. Would be so convenient to be able to do this! Peace!!!
Alex
Is there a relay to pull to disable door chime on my 03 V70?
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
On my 2004 v70 I shut the seatbelt chime off using vida.padzilla wrote: 15 Mar 2018, 18:45 Hi wonderful Volvo folks,
I have a 2003 Volvo V70, with two little ones who like to take car naps. When we are back home I hate to get out of the car because the stupid door chime starts going off which will wake them up. I did a bunch of research and haven't found a way to disable the chime on an 03 V70. Is there a relay to pull? I'd even clip a wire if it was easy to access. All the other guides and posts are for previous generation cars. I even looked through service diagrams with no luck.
Alex
On a previous ford van I put a sheetmetal screw through the buzzer itself.
I think if you pull the key before you open the door you don't get the chime? Unless 2003 is different than mine?
Flashback to the twins in Volvo nap mode, 20 years ago.
Thanks for the replies you two. Abscate your right, the chime is only when the key is in the ignition. I just wanted to be able to open the door with the car running/AC on for them.
Using Vida for this model make sense. Not worth it to me to buy a device just for that but perhaps I'll get one eventually.
Thank you again, always so helpful on here
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
When the DIM (cluster) is disconnected do not put the key in the ignition or an SRS message will appear along with a warning light that can be cleared only with Vida
See this 'mod' at 0:35
- RickHaleParker
- Been thanked: 978 times
On a previous ford van I put a sheet metal screw through the buzzer itself.
Screw the buzzer ... amusing oronym.
Active
Past
Past
- 990 Views
Last post by kallekula
- 616 Views
- 36 Replies
- 2258 Views
Last post by Andrew Vanis
- 1157 Views
Last post by bmdubya1198
- 960 Views
Last post by Conclaire
