1998 S90 stopped running...
anbran123
Year and Model: S90 1998
Post by anbran123 »
Was driving along and the engine just quit. Pulled over and can't get it started again. The battery turns the engine over ok and there is fuel pressure at the fuel pressure relief valve...so I'm assuming the fuel pump is ok.
Any thoughts on what it could be or what to check?
The car normally runs quite well even though its a high mileage car (600,000 km)
Mike
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
Had that happen on a Buick and it ended up being the crankshaft sensor. Are you sure the timing belt is ok? Have you had the codes read if any exist? I loved my 98 S90 the short time I had it. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
I have a '97 S90. If the Camshaft Position Sensor (CMP) is defective the engine may not run. However if you unplug the CMP the engine will start and run in derated mode. Try unpluging the CMP and see if it will start and run.
Active
Past
