Erratic boost with P0245 and P0422
My 01 V70 2.4T has an odd problem, started out while driving in the snow, I got a P0245 code, after that I checked the lines off the TCV replaced any that were broken or bad, no help. Replaced the TCV, now the car spikes to 12-14 psi quickly drops to 0 then rises back to 2 psi. Replaced the MAF, Car idles smoother, little peppier, boost still spikes and drops, Code still persist. I’m lost trying to hunt this down, car is very unpredictable right now
- Been thanked: 4064 times
You need a low pressure precision gauge to test the waste gate valve. You can test it by inspection by rigging an iPhone under your hood to video it,
The blowoff valve is the other one that can go, but you have to remove the cover to inspect. I remember,her spending a fun 3-4 hours doing that once
- RickHaleParker
- Been thanked: 977 times
iPhone are not cheap, why risk damage or loss when USB Endoscopes are cheap ~$15.00.
Active
Past
Past
- 1810 Views
Last post by bmdubya1198
- 818 Views
Last post by docbipe
- 1828 Views
Last post by Sommerfeldt
- 1275 Views
Last post by SpeedGP
- 21 Replies
- 5391 Views
Last post by j-dawg
