04 XC70
Can someone tell what size the torx bit is for the tensioner on the drive belt? I have borrowed the bit in the past and remember it being a T75 but I want to be sure before I buy one. Thanks!
Belt tensioner torx bit
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
If you have the 14mm bolt in the center (there may be a cover over it), you can grab it by this bolt @ 19:20 in this video
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
T60 or 14mm is correct.turbotim2 wrote: 21 Mar 2018, 05:53 04 XC70
The fcp tool makes it easier to get in there.
https://www.fcpeuro.com/products/volvo- ... -8760#desc
- Has thanked: 311 times
- Been thanked: 817 times
14 mm is correct and so much easier than a torx head bit or socket.
Consider a ratcheting 14 mm box wrench with a pipe over it to make the lever long. Then the job is simple and you have a nice wrench you can use in dozens of other places.
- Been thanked: 504 times
I wrote the detailed DIY timing belt, water pump etc. for 2005 XC90.
All the tricks are there.
DIY: 2005 Volvo XC90 2.5T Timing Belt, Water Pump, Serpentine Belt
viewtopic.php?f=10&t=83521
I believe the transition from Torx to 14mm hex head was in the ba$tards 1999.
- 1484 Views
- 14 Replies
- 1575 Views
Last post by Krons
- 10 Replies
- 2895 Views
Last post by dosbricks
- 304 Views
Last post by RedBrickCollector
- 2307 Views
