Closing up thread
The ABS fault cleared it self on the first self test (15 mph, burp!) and all worked well
I now have traction control, STC back just in time for the snow melt.
I'm going to pigtail my spare rear ABS sensor and put it and the yellow connector in the free parts bin for someone on a budget who needs this. One could replace a single sensor by soldering in the pigtail to the pins and reinserting them into the car connector. At a $175 for the harness, I'm sure this would be preferable
1999 V70T5M Replacement of rear ABS sensors and harness 9472171
- Been thanked: 4064 times
FCP has the ATE replacement harness for $50 USD - this may be a clearance price. Im sure this harness will go NLA soon as its a 1999-2000 and C70 1999-2004 only part
Update , you can get the rear harness for-1998 really cheap from this guy on eBay in this thread
viewtopic.php?f=1&t=66624&start=10
But it won't work on the 1999-2000, unless you cut and solder
You can get the ATE version of this part from FCP under part number 9496419
https://www.fcpeuro.com/products/Volvo- ... 70-9496419
