Looking for some opinions, I'm getting a rough idle and some misfires. The car starts out smooth but once the idle comes down to 650 (or thereabouts) it will sputter, sometimes dies, and regularly misfire and or backfire through the intake.
The misfire takes place across multiple cylinders.
I'm getting the following codes:
ECM-3503 Misfire, at least one cylinder - emission agitation
ECM-3513 Misfire cylinder 1 - catalyst damage
ECM-3523 Misfire cylinder 2 - emission agitation
ECM-3533 Misfire cylinder 3 - same
ECM-3543 Misfire cylinder 4 - same
ECM-3553 Misfire cylinder 5 - same
ECM-261A Long-term fuel trim, bank 1 - upper limit
ECM-262A Long-term fuel trim bank 1 - upper limit
Any suggestions on what to try first? My thought was to replace the upstream o2 sensor to start.
Of note, just finished fixing two exhaust leaks so I'm going to assume my exhaust is in decent shape.
rough idle and backfires...
- pierremcalpine
- Year and Model: V40 2003, V70 2010
- Has thanked: 2 times
- Been thanked: 5 times
- pierremcalpine
yaaaahooo! New o2 sensor, car feels awwwwwwesome. Love it when educated guesses work out.
Well that's the good news...the bad news is that I broke one of the screws in half that holds the heat shield onto the motor...damn. I have no idea how I'm going to solve that.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 479 times
I broke one of those heat shield bolts too, they rust out and bind up. It rattles, eventually it will fatigue and break off.pierremcalpine wrote: ↑22 Mar 2018, 11:43 yaaaahooo! New o2 sensor, car feels awwwwwwesome. Love it when educated guesses work out.
What...eva.
- RickHaleParker
- Been thanked: 958 times
Symptoms of a clogged exhaust system.
1. Hook a vacuum gage to a intake port.
2. Observe vacuum at idle.
3. Increase RPMs to 2000.
Vacuum should increase. If it decreases it is because the cylinders cannot push the exhaust out efficiently, creating back pressure on the intake side.
Clogged exhaust system can be Catalytic Converter, Resonator or Muffler. Before replacing an expensive Catalytic Converter, open the exhaust system downstream of the Catalytic Converter. If the back pressure goes away, the clog is downstream of the open. If it does not it is upstream of the open.
- RickHaleParker
I would give the bolt a long soak in penetrating oil. Then with a left hand drill bit next size smaller then the bolt shank, start drilling the bolt. If your lucky the left hand drill bit will bite and spin the broken bolt out. If not you can use a Tap to chase the threads or cut threads for a oversize bolt. Make sure you get the drill centered and drill true.
- Has thanked: 1500 times
- Been thanked: 3810 times
You can wire it into place, zipties, chewing gum - not too bad a thing to deal with.pierremcalpine wrote: ↑22 Mar 2018, 11:43 yaaaahooo! New o2 sensor, car feels awwwwwwesome. Love it when educated guesses work out.
