Hello,
I looked around the web for the location of the fuel pump and sending unit, and took the back seats out of mine, there were two access panels under the seats so I removed them but no fuel pump under there? See photos..Where is the FP Located?
Fuel Pump Location on 2003 V70 Wagon
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Hi, would you mind tell us what is the actual issue? I'm asking because these pumps almost never fail, however many mechanics want to replace them as they do on other car brands. Most of the time, a fuel delivery problem is related to the PEM module or to the FPS sensor.
alanjackson
- Year and Model: V70 2006 D5
- Has thanked: 2 times
Hello, I have a not starting problem, there is no fuel at the schader valve on the fuel rail of my 2002 V70 petrol car, with the valve core removed there is no fuel coming out when the enging is cranked over.
Cannot hear the pump running in the tank.
I have searched under the car near the filter and in the spare wheel well but can't find the PEM.
Any idea where the thing is supposed to be anybody? Thanks
- Has thanked: 1611 times
- Been thanked: 4071 times
It is probably on top the tank
I’ll link to the thread, but if you find the part number that’s the bullet proof search method on MVS
viewtopic.php?f=9&t=84169
- Year and Model: Lots
- Been thanked: 128 times
The 2002 model has no PEM. That was a later inclusion.
Did it use the 1999-2001 style pump or was it a true 2002 Bastard design?
Ill carve this thread out from the 2003 one shortly
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The original post shows the steel tank ports. The wires and fuel line are not on the tank hole cover on those. There is no LH side ejector or level sender as that tank is flat bottomed and has no issue with trapped fuel. fuel pump pic from RockAuto shows no harness to a lid as the lid is not part of the pump/sender unit.
- oragex
A bit of confusion here as the original poster has a 2003, while the second person who brought back this topic today has a 2002. So for a 2003 I would first look at the PEM see if it has corrosion.
For the original poster with the 2003 car, the pump is in your first picture, but I would warmly recommend not to blame the pump in the first place, Volvo pumps are very long lasting - at least don't discard it if replacing it. Also, there is a pump relay under the dash https://www.volvoforums.org.uk/showthread.php?t=116617
Might be worth also replacing the FPS with a used one.
Also, read a bit about 'catching' the pump pipe that goes into the other side of the tank, so you don't loose it inside the tank
- 4095 Views
Last post by Lowmiles
- 1379 Views
Last post by CanadianRob
- 3735 Views
Last post by Ozark Lee
- 510 Views
Last post by Faust
- 11 Replies
- 520 Views
Last post by vtl
