P0455 - Will CEL go off?
Shamiks V70
Year and Model: 1998 V70
Post by Shamiks V70 »
We found what we believe the problem that was causing the CEL to come on and code showing P0455 on Saturday and made the correction on our 1998 V70. Will the light turn off by itself or do we have to turn it off? I need to run this through the emissions testing soon and this seems to take forever to reset to ready. Thanks in advance.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
No it will not go off by itself.
Has thanked: 1611 times
Been thanked: 4071 times
If I remember the software right it takes 46 cycles without an error to reset an emissions CEL - this can take a long time, as in months.
it will be much faster to either reset with a code reader, or disconnect the battery for 10 minutes.
You will have to drive it for about a week to have the monitors 'go ready' for inspection - if they arent ready you fail automatically, even if there are no codes.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
You'll have to clear the codes and let the car go through its drive cycle before it'll pass inspection. Otherwise, like abscate said, the monitors will not all be ready.
esl_97_850_T5
Year and Model: 1998 S70 GLT
Has thanked: 18 times
Been thanked: 27 times
Post by esl_97_850_T5 »
Don't know about your state/county, but in my county, my '98 S70 GLT has always passed inspection (via the old tailpipe smog test), even though it has **never** -- in 2 years of ownership -- had all OBDII Readiness monitors be READY at the same time. The previous owner, in another state, had the same problem, and he also followed the below procedure to pass his inspection.
1. Be sure the gas cap is on tight.
2. Always reset DTCs or disconnect battery immediately before driving the 3-4 miles to the emissions testing station. Sometimes I even do the DTC reset while in a nearby parking lot. This is necessary to ensure that no OBDII Pending DTC is lurking hidden, ready to set the CEL while the car is idling before or during testing.
3. Mention to the emissions testing personnel that they'll have to do the tailpipe test.
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
Shamiks V70
I don't think the tailpipe test is an option for us.
800artfreed
Year and Model: 98 S70T5; 99 S70GLt
Been thanked: 26 times
Post by 800artfreed »
If you are in Maryland you can have 1 or maybe even 2 monitors not ready. They will still test and you will pass. 1998 volvos are recognized as having a difficult, lengthy & tedious drive cycle to have all monitors ready. Check your motor vehicle administration web site for emissions testing exceptions
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
I had thought that VA was safety inspection only (it has been ~20 years) so if you have the option to "live" there then do so.
https://www.dmv.virginia.gov/vehicles/#emissions.asp Unless you live in those couple of counties listed apparently...
2023 Lexus RZ450e -66k
