DIY 2005 XC90 INNER Door Handle Fix (Can't open from inside)
Been thanked: 504 times
Post by cn90 »
If you can't open the door from inside, check "Child Lock" thingy first. Happened to my RR door: cable came off INNER door handle.
Same issue in P80 (Volvo 850, S70 etc.).
Since this is an easy fix, I did all 4 doors with zipties and I have have tool and technique down.
It was only 10 min per subsequent door.
Chances are the plastic clip holding the door cable is cracked and this allows the cable to detach.
The good news is: this is easy fix, about 15 minutes max.
1. Watch this youtube video by "1AAuto dot com":
2. When prying the trim piece, pry gently to detach it so it moves a bit toward you. There are 3 tabs that click in. Don't break them.
Just gently pry it toward you, then up.
3. Then Torx 25 screws x2.
4. Pry around the door trim using upholstery tool wrapped with cloth.
* There are 9 plastic clips.
* Electrical connector(s): d/c it.
5. Now study the design where the cable is attached. Use your common sense.
* I drilled 5/32" holes for ziptie to wrap around the door cable.
* Just drill near the base of the side plastic partitions as shown, near the base, this way it is more solid.
Don't drill the hole near you, go for the base of the partition.
That is all, very very easy fix...
WilliamBoot
Year and Model: XC90 2006
Post by WilliamBoot »
I couldn't quite make sense of your photos - wasn't sure what you were drilling, but took your advice to figure it out. When I'd finished, I looked again at your photos and they made perfect sense. Thanks! Obviously I'm not a visual person. :-)
Geno9707
Year and Model: 2004 s40
Been thanked: 3 times
Post by Geno9707 »
Hello I had the same issue.. easy repair.. I got a well pre owned genuine Volvo door handle on eBay here is the link..
https://rover.ebay.com/rover/0/0/0?mpre ... 2446861108
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
I had a similar issue where the cable failed on my drivers door. I replaced the lock mechanism, too, but in retrospect it would have been fine to just replace the cable.
Nice photos!
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
zoli_m13
Year and Model: S60 2001
Post by zoli_m13 »
Hi cn90,
Thx for the great idea - it works well in my 2001 S60.
viewtopic.php?f=9&t=69305&p=488870#p488870
Cheers!
2001 VOLVO S60 2.0T A/T 245K+ miles
https://goo.gl/photos/jS1z777LDqJSQqPDA
Geno9707
Post by Geno9707 »
[quote=Geno9707 post_id=485073 time=1539407253 user_id=99218]
https://rover.ebay.com/rover/0/0/0?mpre ... 2640607949
Geno9707
Post by Geno9707 »
Hello update I was able to find the part to replace the inside door handle in the XC90 2003-2012 interior door handle here is the link..
http://rover.ebay.com/rover/1/711-53200 ... olid=11111
John1518
Year and Model: 2006 XC90
Post by John1518 »
I had to make an account just to say thank you for this post. It was a ten minute fix and saved me a lot of head scratching!
VolvoXC90V8
Year and Model: 2005 XC90 V8
Post by VolvoXC90V8 »
I also had to make an account to personally thank you for this fix/write up. I followed your instructions exactly and was able to fix my door handle for $0. Thank you!!
Post by cn90 »
I am the original poster, and posted this DIY in 2015, 10 yrs ago...
All doors work fine 10 yrs after this free fix!
