ECM-6110 Engine Cooling Fan Relay - Signal Missing
carboncow
Year and Model: 2003 XC70 2018 S60
Post by carboncow »
Friend bought a very clean but mechanically basket case 2002 XC70. One of the several codes I"m not familiar with is:
I had to replace a fan module (or the whole fan I forgot) on my 2003 once but that was the fan stuck on high even with car off.
Is this a small black relay somewhere or is this in fact the main module?
What can you guys tell me?
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
I believe there is no dedicated Black Relay for the cooling fan; its speed control module is the grey box on the fan shroud like in this picture: https://www.fcpeuro.com/products/volvo- ... 30680547oe
I will try to locate the electrical and confirm later on today;
Thanks
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
regent
Post by regent »
ECF on 2002_S60.pdf
(47.25 KiB) Downloaded 751 times
Sorry could not get to the exact YMM schematic, but the arrangement on the attached page is very similar (if not exactly the same)
The Control Module 4/71 is on the Cooling Fan 6/29 shroud; the assy is hot-powered (Red Wire) from Batt+ via fuse, and is PWM-driven (violet wire) by the ECM.
The SB is chassis ground.
The code indicates that the ECM cannot see if the fan control is being powered and/or driven; I would check the connector on that violet wire (loose, recessed or oxidized pins) and then verify solid +12 volts between the Red wire and ground (with a light bulb) before condemning the fan control. These usually fail shorted so the fan will run on high.
If wiring checks good, then a trip to the bone yard for a whole fan assy will be well in order :D
2015 BMW 335i
julesvern
Year and Model: Volvo V70XC 2002 VOR
Has thanked: 3 times
Post by julesvern »
You will have an error ECM-6110 in case of replacing fan-module for the restyle one, high efficiency type - it has twice much blades on it, and integrated with motor control unit
People say the configuration should be changed at dealer of elsewhere for ECM to realize that new unit type was installed. Unfortunately its not "plug and play"
Have same issue by now. Fan is working fine and correct, only the error in Vida is an issue.
P.s. those are the mentioned visual differences
