bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Re: What did you do to your Volvo today? (now Sticky!!)
Post by bmdubya1198 »
Aaaand the alarm is going off again. I give up.
Has thanked: 1505 times
Been thanked: 3817 times
Tailgate wires??
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
abscate wrote: 30 Mar 2018, 18:22 Tailgate wires??
Don't they have a way in the 98's to determine which switch/sensor is causing the alarm similar to the '99?
bmdubya1198
Yup. Fixed that wire 3 times.
wizechatmgr wrote: 30 Mar 2018, 18:34
I know it’s the tailgate latch, it goes off after I open the tailgate when I unlock it with the key.
This tailgate harness if driving me nuts!
bmdubya1198 wrote: 30 Mar 2018, 18:45
I think that’s normal function. The fob or the driver door disable the alarm, the trunk lid does not
bmdubya1198
Then why the heck is there a key hole there? Volvos... :roll:
They dropped it a year or two later, 1999s are special
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
bmdubya1198 wrote: 30 Mar 2018, 07:35 Had another good day yesterday at the junkyard. Initially I went for a couple relays, my cousin says "I'm probably not getting anything." Naturally we ended up coming home with a 19t and an S60R exhaust manifold, along with a larger intercooler (though I'm not sure the brand).
Same car he got his e-code jewels from as well as a Supersprint exhaust. I at least got an R steering wheel from it. I would have loved to get that car before it ended up there... black on black manual '99 C70 HPT coupe. The only thing that would have made it better was if it was a non-sunroof '98. Fortunately between me and my cousin we bought up all the valuables!
did you grab the ecu by chance, sounds like stage III with a 19t and exhaust/intercooler upgrades. What about the injectors?
Current Volvos:
bmdubya1198
FLXC90 wrote: 31 Mar 2018, 11:02 did you grab the ecu by chance, sounds like stage III with a 19t and exhaust/intercooler upgrades. What about the injectors?
It's ME7, so I did not grab the ECU. I don't know what's entailed in re-coding it to a different car.
It had blues, and I didn't grab them. I do plan on getting them next time if they're still there, though.
s10lowrider1994
Year and Model: 2000 v70
Been thanked: 3 times
Post by s10lowrider1994 »
New coolant reservoir and sensor (bye coolant light) and tidied up the mess of dry rotted wire loom under the top cover. Timing belt job this coming week and hoping to hit 300,000 miles shortly.
