Hello, my wifes trusty 02 wagon has developed a problem with the remote and the key.
We have only one key and she has already been stranded once locked out of the car. The remote will not lock or unlock the car, so you cant park it anywhere for very long because it's not secure.
replacing all of that at the dealer could be very expensive.
I was wondering if I could remove a set of locks, keys, remotes, ignition etc. from a 02 xc70 that is being parted out and replace the ones in her car. Is that feasible, and if so is it a major PITA?
key / fob / remote swap from one car to another?
- fastgroceries
- Year and Model: 1996 Platinum 850
'96 Platinum 850 #1 - was restored, but pretty beat up (long story)
'96 Platinum 850 #2 - mostly restored, mostly original, mostly a money pit
'02 V70-XC - Mom's indestructible vagen
'12 Nissan Frontier Pro4X - For hauling Volvo parts
- Been thanked: 466 times
- Been there done that.
- Option 1: new key is about $180 ($75 for key, $30 for "software license" and $70 programming fees). This is day light robbery but it is what it is.
- Option 2: use the key manually, ignore the fob. This is what I have been doing for a long time.
- Has thanked: 1500 times
- Been thanked: 3810 times
My indie does keys all in for $40
You cannot transplant keys and modules on the P2 platform
93SCMax
- Year and Model: 2001 V70 T5 mt
- Has thanked: 36 times
- Been thanked: 44 times
Agree with above posters...can't transplant and most likely (best) option is to use key in door.
Two other things to check:
1) Confirm you've changed out the key fob battery and installed it correctly.
2) Open up the key fob (should be one phillips head screw). Split the casing apart and remove the rubber boot underneath. Double check that the solder attachment points on the circuit board for both the lock and unlock buttons are not broken. I've found that after years of pressing, these can break and cause your issue. If broken, how good are you with a soldering gun?
Good luck. I can't live without my key fob.
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
Find doublebug (Henry) on the board. See if he can reprogram / pair a new remote for you - you will need an OBD2 cable..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- fastgroceries
Thanks for the great replies. I may not have stated what I wanted to do correctly.
My wifes 02 XC70 has a problem with the locks. The key does not work in the door and the remotes dont work.
If I could locate a junk car - with functioning keys, locks, ignition and remotes - could I transplant those parts into my wife's car?
93SCMax
Question: When you press the key fob lock or unlock button, do you hear a clicking in the driver door? If so, it may be the grommet (plastic) holding the rod that unlocks/locks the door is busted (ie. the rod is disconnected). It could also be your door lock mechanism has gone bad...that can be transplanted from a donor car. Make sure you get the same PN (S60 and S80 mechanisms could have the same PN). It may also be electrical (not key fob related), like a fuse or relay or door lock mechanism unplugged.
With the new info, I'd focus on the door lock mechanism. Not too hard to change if you have a little mechanical skill...I've transplanted a few from the junkyard. As I recall, a new one from Volvo is > $100, junkyard, probably < $20.
Good luck.
Good luck.
No. I assume you mean can you transplant them and have them work.fastgroceries wrote: ↑03 Apr 2018, 23:00 Thanks for the great replies. I may not have stated what I wanted to do correctly.
