I hope y'all taking time with family and friends this Easter Sunday.
I'm on 3rd annual oil and filter change since switching both our cars to full synthetic, that is, oil and filter change once a year.
Our 1997 850 runs on Platinum Euro Full Synthetic 5W-40, see this thread viewtopic.php?f=1&t=74828#p460884. 5W-40 has now proven to crank effortlessly under extreme temps during overnight curbside parking.
Over on V70XC, it is Platinum Full Synthetic 5W-30 grade. There wasn't much loss of oil on dipstick, but the bottom of oil filter housing collected fine material mixed with oil -- a teaspoon worth. Here is a photo of oil pan before the oil & filter change. What to expect?
2001 V70XC - Switched to Pennzoil Full Synthetic 5W30
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I think the pan is tilt towards the rear so the oil will accumulate at the rear bottom of the pan but may be leaking actually from the front of the engine ? I stand corrected. If it leaks from the front of the engine, look with a flash light if it leaks from under the intake manifold, it could be a broken PCV hose. The PCV on these cars needs be done preferably around 80000 miles.
If the leak is from the rear it may be the oil cooler (the black part in the picture)
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
Just after my first oil change on this S60, I was fooled by a minor spill at the oil filler that had slowly made its way down to the pan.
(I thought I had cleaned it up) but it looked like a scary leak from the top PCV hose.
... that was over 10 years ago
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
Penzoil Platinum has caught my curiosity also, primarily because it's a group 5 made from a relatively new process. I haven't tried it through. Supposedly it does a really good job keeping combustion deposits at bay.
- dlundblad
- Year and Model: 2002 S60 2.4t
- Has thanked: 6 times
- Been thanked: 4 times
I would just run an A3/B4 in both Volvos. One oil for both cars.
Mobil 1 0w40
Castrol 0w40 or 5w40
Valvoline 0w40 or 5w40
Pennzoil 0w40
I switched the S60 over to 0w40 almost 4 years ago. No more sludge in the oil filter either.
Mobil 1 0w40
Pennzoil 0w40
Hers: Charcoal 2002 S60 2.4t 187k
- dlundblad
Do you mean the GTL process? Gas to liquid.mrbrian200 wrote: 02 Apr 2018, 13:58 Penzoil Platinum has caught my curiosity also, primarily because it's a group 5 made from a relatively new process. I haven't tried it through. Supposedly it does a really good job keeping combustion deposits at bay.
Mobil 1 0w40 is GTL as well if that matters to you.
Just don’t mix Shell and Mobil oils. Either one is fine, don’t mix.
- dlundblad
All current engine oils are compatible. No issue whatsoever.abscate wrote: 04 Apr 2018, 20:00 Just don’t mix Shell and Mobil oils. Either one is fine, don’t mix.
What if someone had Mobil 1 oil, but did an oil change and switched to Pennzoil/ Shell? You can bet the new oil is mixing with what was left in the sump.
