Clunk when braking after reversing
Rocambolesque
Year and Model: 2000 S70 SE
Been thanked: 5 times
Post by Rocambolesque »
My 2000 S70 has this problem: I hear a loud clunk (sometimes it's only one, sometimes it's 2-3 clunks all at the same time) the first time I brake after changing from reverse/drive. Example: I park my car nose first at my house. I back out of my parking spot. When I brake, I hear the clunk because it's the first time I brake on reverse. Then I put it in drive, brake at the bottom of my driveway, I also hear the clunk because it's the first brake application after changing from reverse to forward... If I brake again going forwards, I won't hear it again...
Basically it's like if the braking force while going forward moves someting and the braking force going backwards moves it the other way. The acceleration force it never enough to move this. I checked the wheels for play, everything seems tight. Rear shocks and mounts are new. Any ideas?
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
I had something similar in my '00 V70 after replacing rotors, pads and brake shoes. One brake shoe had escaped from its retaining clip and was in a weird angle against the inside of the rotor/drum. The clunks would come and go, sometimes pulling up on the parking brake lever while moving would cause a loud clunk and sort of reset it.
The fix involved removing the rotor and putting the brake shoes back into position. It was tough to get the rotor off, but with some prying, it finally came off to reveal the problem. Good luck!
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
800artfreed
Year and Model: 98 S70T5; 99 S70GLt
Been thanked: 26 times
Post by 800artfreed »
Please check the lower control arm bushings where mounted at the sub frame at the front of the car. I had a similar noise and one arm had totally shot bushings. New control arms solved the problem and of course the car handled better too!
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
Rocambolesque
I'll definetly check the control arms, the car has vague handling too...
Has thanked: 2199 times
Been thanked: 1851 times
Also check the rear suspension delta link bushings.
Rocambolesque
scot850 wrote: 03 Apr 2018, 20:07 Also check the rear suspension delta link bushings.
Yes, this makes sense as the noise seems to come mostly from the rear. How do you verify that those are bad? Like all cars older than 5 years here, everything is rusty... I tried moving the wheels by hand, I thought maybe the whole delta link would move, but it doesn't really work. Also, what is the best place to buy the special tool? I don't have a 3500 Suburban to hook a come-along to :)
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
I'm with Brunoceros; Do you use your "Parking Brake", does it work properly?
Current Volvos:
The tool can be loaned I believe from MVS. Abscate can you enlighten on this?
Has thanked: 1609 times
Been thanked: 4065 times
Both tools are NLA as of March 2018, Matt...any plans to bring Big Blue back?
