So I have a 2003 Volvo v70 that I got as a gift from my aunt. Right after I got it I got the "SRS-Airbag Service Urgent" Message on the instrument cluster. I took it into the shop, after using the Vida they told me they found the codes "SRS-00D4 Fault Lamp, DIM-0005 Red Warning Lamp Circuit." The shop notes say "Tested function of bulb okay at this time, problem seems to be in the circuit inside the cluster."
They quoted me $1500-$1600 to replace the cluster and re-flash with factory software
I love doing things myself on my cars so I'm trying to figure out my options and get this fixed myself.
I understand there are DIM repair services where I can send in my DIM. Anyone on here have experience with any of those or recommendations? Any ideas on how much this would cost?
I would still need to buy a VIDA Dice to clear the code once the repaired DIM is reinstalled is that right? Would any Vida off eBay do the trick or is there one you guys recommend?
What about finding a refurbished/used DIM cluster. Worthwhile or price effective option? Is it plug and play to install it or do I need even more equipment to attempt this.
Just trying to figure out the simplest/cheapest method to get this done.
Let me know!!!
