2002 C70 Conv 2.0T O2 Sensor locations
Andihowe1975
Year and Model: 2002 C70 2.0T
Post by Andihowe1975 »
Good Morning All,
Apologies in advance for a simple question.....
I have a 2002 C70 2.0T Convertible that I have just acquired that has a few fault codes. The first two are relating to the O2 sensor and O2 heater element.
On crawling about under the car, I have only found one on the cat facing rearwards, is this the only O2 sensor on the car?
Thanks in advance
Andi
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
1st one is between intake manifold and cat,second(rear) one is after the cat...towards the rear of the car.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Andihowe1975
Thanks Misha, If I can work out how I can post a pic I will show you the one Ive found. Will need to work out which one I havent then....
Andihowe1975
download/file.php?id=2666&mode=view
This is a pic of the same thing that I have found. Is this the front O2 sensor? If not where would be the front one be?
misha
Post by misha »
I can't see clear from the picture you posted....but i just told you in the previous post....1st(front) one is between intake manifold & cat.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Andihowe1975
So is it on the part of the pipe that is running vertically up the bulkhead then?
Andihowe1975
In the pic I attached the sensor is bolted into the top of box on the exhaust (the part with the red arrow on) which Im assuming is the cat. I did look up the exhaust towards the manifold but couldnt see anything jumping out at me. If your saying that there should be a sensor on that part of the pipe then I will need to jack it up and have another look.
Thanks Again,
Andi
misha
Post by misha »
Yes...front o2 sensor MUST be between intake manifold & cat.That's why it's called 1st or front.
Rear o2 is ALWAYS after the cat towards the rear end of the car....and thats why it's called 2nd or rear.
Some cars have them both,some have only front one.
Check if your 2.0T is equipped with both or just have one...but being a '02...it should have both.
This should match your setup:
https://www.pelicanparts.com/techarticl ... cement.htm#
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
