2001 V70XC - Switched to Pennzoil Full Synthetic 5W30
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
One of my trusted internet myth sources (which I cannot reveal) just confirmed that the M1 and Penn won't mix at all, they will stay separate like mercury in water :lol:
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
At the recent oil & filter change, the action of pulling up dipstick was free of any resistance. The two o'ring were dried and cracked so replaced both with Volvo's.
It now takes some effort and seals better. What to expect, change in crankcase pressure etc?
regent
Post by regent »
xHeart wrote: 18 Apr 2018, 08:24 At the recent oil & filter change, the action of pulling up dipstick was free of any resistance. The two o'ring were dried and cracked so replaced both with Volvo's.
Yes - only if you have a very neglected PCV system (which I doubt).
You could as well do the Rubber Glove Test and prove me right (or wrong) at any time :D
2015 BMW 335i
Been thanked: 4065 times
dlundblad wrote: 05 Apr 2018, 06:57
abscate wrote: 04 Apr 2018, 20:00 Just don’t mix Shell and Mobil oils. Either one is fine, don’t mix.
All current engine oils are compatible. No issue whatsoever.
What if someone had Mobil 1 oil, but did an oil change and switched to Pennzoil/ Shell? You can bet the new oil is mixing with what was left in the sump.
Your engine will Schmell...
Off to carve another notch under my bridge...
dlundblad
Year and Model: 2002 S60 2.4t
Has thanked: 6 times
Been thanked: 4 times
Post by dlundblad »
abscate wrote: 18 Apr 2018, 09:37
The mark was well deserved.
You definitely got me.
Hers: Charcoal 2002 S60 2.4t 187k
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
Abscate was adding his special humor to the conversation! Once a year oil changes are crazy in my opinion in a old engine no matter what oil.
I use Redline 10W30 in my 2004 S80 T6 which is a group 5 oil, but a estar based product. Even though Ester is supposed to be the most stable base available I certainly won't leave the oil beyond the 6 months Volvo recommends and never the 7500 miles per Volvo either. It seems to me my 14 year old engine has to be allowing more contaminants past the rings polluting the oil than when new. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
The six months is to accommodate the use of mineral oils though. It's never been shorter than a year since at least the 80s over here. A lot depends on driving patterns as well though.
dlundblad wrote: 18 Apr 2018, 19:07
Full disclosure.... that zinger Is from car Talk, the NPR car show by the Magliottzi brothers. ( creative spelling mine)
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Agree, 6 months is rather for mineral, a good synthetic should last a decent 12 months and/or 7000 miles in a region with mild climate given the engine runs in good condition.
But the best really is to send an oil sample (for ex to https://www.blackstone-labs.com/ - p.s. I don't work for them). This should put an end to any doubts.
As June said, engine condition is critical for engine oil life. A more or less good working PCV system may cause oil contamination, not to mention a less optimal injector spray pattern (incomplete gas/air mixture combustion), stuck piston rings, clogged VVT solenoids, plenty of things that may cause the engine oil to get contaminated.
Rattnalle
Post by Rattnalle »
The purpose of the oil is to get contaminated so that nothing else is ;-)
I still don't get oil analysis though. All it seems to tell you is whether you've gotten the engine warm enough to boil moisture and fuel away and if you've got a coolant leak. Both quite easy to tell if you're the one driving the car yourself regularly.
