- Plastic fuel tank: get underneath the car and look.
- Or look in the trunk.
- I think it is time for you to get a used PEM from junkyard or ebay.
Fuel Pump Died Again? 2003 V70
alexv702003
- Year and Model: 2003 V70
I bought a used PEM. Going to replace mine soon. Any tips on how to replace it on a metal fuel tank?
- Been thanked: 504 times
I already showed you the trick in my previous post above.alexv702003 wrote: 05 Apr 2018, 19:28 I bought a used PEM. Going to replace mine soon. Any tips on how to replace it on a metal fuel tank?
Back right wheel up on a ramp.
7mm hex on a small 1/4 drive ratchet, undo the hex bolt until it comes off,then reach up and pull the metal spring , sort of stamped sheet metal version, off.
Ease the wiring from the metal clip,opening with small screwdriver helps
Then slide the PEM to the right, lift up and out.
Total, about 5 minutes
You can also search threads for part 8634953 and 30769225 for procedures and pics
I think the 30769225 is more inclusive
- Year and Model: Lots
- Been thanked: 128 times
PEM is fitted to 2003 plus cars
alexv702003
- You keep saying "metal fuel tank" in your posts, but looking at it, it does not look like "metal" to me.
- Also, post better photos (camera closer to the ground so it covers more area).
- Search forum for other locations: under REAR seat, trunk etc.
- Post back what you found.
It is toward the rear of the tank, if its on the top.
- 10 Replies
- 2441 Views
Last post by bmdubya1198
- 17 Replies
- 4549 Views
Last post by volvolugnut
- 13 Replies
- 12247 Views
Last post by SVO LOU
- 22 Replies
- 3844 Views
Last post by Skenda02
- 1366 Views
Last post by CanadianRob
