Cooling fan 2000 S80
Pilot9302
Year and Model: 2000 S80 T6
Post by Pilot9302 »
My cooling fan will not come on. I replaced it and still won't come on.
Last week after I changed my oil, the fan started working but the temperature gauge stayed at 0!
After a while the temp gauge worked again, but the fan would not come on again!!!!!
HELP!!!!!!
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I'd look into the coolant temp sensor both the sensor and the wiring all along
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Is it running hot? Is the outside temp above 70F with a/c running?
The fan will not be operated by the ECM until coolant temp reaches 225 or a little more and in cold weather it takes a long time sitting still running to reach that. If it isn't warm enough then the a/c high pressure will not be high enough for ECM to run fan for a/c needs.
