2005 V70NAM56 CATHERINE 496197 Manual 5 into code A981 Saurus 15inch wheels
Forum rules
Has thanked: 1609 times
Been thanked: 4063 times
Checking for DTC codes
turn on ignition. hold the READ button in on the end of the turn signal stalk. push the rear fog light button twice and then you can release the READ button.
Now you can use the READ button to scroll through the modules to see if codes are present. Expect some to be present in DDM and PDM since playing with those switches and holding too long sets codes.
"READY" means no codes, DTC SET is self explanatory, and "CHECKING" means that module has not completed diagnostics (but there are no faults or it would read DTC PRESENT)---usually has to be driven to change this status. ECM will take maybe 20 miles of mixed driving to clear this one to READY.
You can't see what the fault is but at least you can see if it is loaded with codes if the list has dtc's in most modules.
I have a 240K mile 2004 V70R and other P2's in family and friend group. I am doing far less to these with higher milage and age than I ever did to the 850/s/V70 ones. The dashes don't break, evaporators don't leak, and heater cores fail less compared to those.
Troubleshoot running light failure
Very slight left FWB growl? Definitely eases on right turn.
Mileage 110xxx
Fuel pressure specs P2
viewtopic.php?f=9&t=63132Thread describing two different fuel line release tools
Getting an occasional BCM-0700 brake fault
viewtopic.php?f=9&t=85197&p=482578&hili ... BS#p482578
Seems to be hot weather correlated
Fuel pressure sensor specs thread
viewtopic.php?f=9&t=81401&p=440613#p440613
Oil filter change 112500
Interesting discussion on P80 bastard early P2 late P2 damper motor AC
viewtopic.php?f=9&t=81951
Clutch pedal slow to return, spinning noises when engaged.
Removed transmission and replaced disc plate release bearing slave cylinder
Replaced left front wheel bearing with FAG
viewtopic.php?f=9&t=82676&hilit=Release+bearing
Need new lower torque rod and front engine mount ( called RHS mount in VIDA)
Coolant changed, Volvo
Mileage 116314
Replaced lower torque rod
PEM service here to fix miss, no-start due to fuel delivery
viewtopic.php?f=9&t=84169
