2001 V70T5.. Time to do something about the worn fronts seat, and the non working seat heaters.
I have read a little about job, from the standpoint of replacing the entire seat, but I read some stories about how the seat controls will stop working, CEM type stuff, that could require a reprogramming to the Replacement seats. I read one suggestion to swap the seat control module back to the original, but then, that didn't always work.
I thought about the alternative, which would be to just reskin the seats, hognose pliers, etc., but that look like I will have to pull the seats out of the donor car and my car, to do the job, and to me, that sounds like I could be risking creating a seat control module problem.
skill is not an issue, I have done both jobs before on other cars. Reskinning was a big PITA, though... The seat swap thing looks to be the easiest, but riskier.
The seat heaters should just be a job of continuity on the heaters themselves to make sure the wiring isn't broken, then checking relays and power. And trying to fool the thermostat into thinking it's cold enough to make the heaters come on.
BTW - any seat from 2001 to 2005, 60, 70 and 80?
Input, advice, etc.?
reskin or replace front seats?
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
I am lucky to be close to a parts yard that always seems to have at least 6 donors there. I go there every time they have a new car there. Luck...
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- Has thanked: 1611 times
- Been thanked: 4073 times
You should buy up each seat for $50 and sell the skins for $150azureblue wrote: 07 Apr 2018, 11:06 I am lucky to be close to a parts yard that always seems to have at least 6 donors there. I go there every time they have a new car there. Luck...
I thought June paid about $400 from Volvo
- June
- Has thanked: 523 times
- Been thanked: 261 times
$400.00ish times two, back and bottom separate. My car is in Volvo right now for a rear main seal, breaks all around, and Glory Hallelujah The seat skins will be installed as well. Hopefully I get her back Monday! Juneabscate wrote: 07 Apr 2018, 13:42You should buy up each seat for $50 and sell the skins for $150azureblue wrote: 07 Apr 2018, 11:06 I am lucky to be close to a parts yard that always seems to have at least 6 donors there. I go there every time they have a new car there. Luck...
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- SuperHerman
- Been thanked: 207 times
It is not a tough job. I swapped out seat covers on my S60 from another S60. If I recall correctly I had all the issues you mentioned. My work around if I recall correctly was to use the entire upright from the donor, and then swap the seat cushion and cover over to the original frame. This maintained all the electronics. Your approach may vary if you have heated seats depending on what you buy. I also had to jumper the electric motors to gain access. This was for a 2001 S60
On my 2005 V50, my daughter left the sunroof open and ruined the leather. I bought a used seat and just swapped over the covers. The only item of concern was the seat weight sensor worked on the original and not on the new seat, so I had to take it apart again and move the original back.
It is not fun, but not that bad a job. In the end for the S60 I had nice leather seats with no cracks or aging rather than ratty vinyl and on the V50 I had clean leather once again.
azureblue
I hadn't thought of using the entire seat back. That would save a bunch of work there. Thanks - great idea....
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
On a P80 the back skin slips down the padding while the seat cushion can be removed with the skin. Is theP2 the same ?
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
Upholstery shop in Hackensack charged $350 for doing the driver's seat in my 2002 with DEAD ON matching vinyl.
I couldn't've been happier.
A leather shop in Teaneck wanted >$750 to reskin THAT ONE SEAT.
I’m feeling better about my 4 hours to reskin my P80...even SWMBO thought it looked good
