So I just gave this a look (rather dark out...) and I appear to be stupid and in need of additional info. It looks like the recirc motor in held by a metal bracket and the motor itself has maybe one fastener that attaches it to said bracket. Do I remove the bracket or just the motor, and which method is suggested?
What is the fastener? Torx? Phillips? I wasn't able to see clearly. Is this one of those where I'm going to want a flex shaft to remove it?
The recirc motor isn't turning and my feeling is this is likely because I already have a code set in the ECC for it. The connection to the recirc shaft was totally off the motor but appeared to be in the correct number of pieces.
Night time repairs - the fun ones =)
Removal of '99 V70 Recirc motor? Topic is solved
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
- Been thanked: 4068 times
I’ve had a look at this a few times and I thought I reached the conclusion that the dash had to come off. It didn’t look easy
Maybe with a flex you can do it?
- Has thanked: 2203 times
Which motor do you think is the re-circ motor? The servo motor behind the glove box?
- wizechatmgr
Yes, the one that at one point had the linkage (disconnected) that goes to the recirc flap.scot850 wrote: 08 Apr 2018, 23:07 Which motor do you think is the re-circ motor? The servo motor behind the glove box?
All data says it comes out after glovebox comes out
Make sure you note where the lever is or once you replace the motor cycle it with the ignition on to find its rest position before fitting the connecting arm which break easily with age. They are still available new as of last year.
Once arm has bee disconnected, you have to remove the one Torx screw and it slides out forward. It is the easiest of the motors to replace once the glove box is removed. When refitting make sure it has sat back into the slider correctly and insert the one Torx screw.
- wizechatmgr
Glove box is out. So the motor just comes off the bracket and the bracket stays in position?
Yes.
- wizechatmgr
Awesome. Thanks!
Get some sleep first, so you don't Charlie Foxtrot your climate system
Ive got the Connolly leather stuff if you want me to lube your seat.
Uncomfortable pause...
- 1207 Views
Last post by Whittiervolvo
- 1187 Views
Last post by jreed
- 1637 Views
- 578 Views
Last post by FMradio
- 1346 Views
