What is "normal" oil consumption? Topic is solved
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 53 times
Post by callahanoffroad »
I think my 95 2.4L is burning oil faster than it should be. Maybe 1qt/1000 miles. I've never gotten an answer as to what the tolerance is before it's time for an overhaul. For example 1qt/1000 miles is acceptable oil consumption in a 350 chevy. Greater than that it's time for an overhaul.
What should I be looking for in this 2.4l engine?
Compression test?
Leak down test?
My exhaust is pretty clear, no blue puffs at startup like my old car. I'm wondering if my rings arent going.
Any thoughts are invited.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Factory says that 1l/1000km is the upper limit of oil consumption.
Depends of oil viscosity.
These cars burns oil from factory....mine was burning 1l/10k km from new.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1613 times
Been thanked: 4077 times
Another topic along the lines of " What is the true religion" and "Who put the hole in June's upholstrey?" that can only lead to the darkness of the internet...
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
I'd say normal is at most a litre per service interval. And that's 15000 km. Mine didn't take that much at almost 350' km.
Those upper limits are just a liability thing. They're not normal.
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
abscate wrote: 11 Apr 2018, 12:14 Another topic along the lines of " What is the true religion" and "Who put the hole in June's upholstrey?" that can only lead to the darkness of the internet...
Mike put the hole in june's seat! June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
What oil are you running? 1 qt/1000 miles is a bit high. If I were you, I'd try sometime like Mobil 1 10W-40 High Mileage and see if anything changes.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
The crankcase vent system needing to be serviced can cause high consumption, especially if the drain passage in block to below oil level in pan is plugged. That keeps the condensed oil from vent box from going "home" and that oil then goes through the intake and is burned. I don't recall seeing an 850 smoke from that. Are the spark plugs very heavily deposited if you inspect them?
FLXC90
Year and Model: 98 V70 T5
Been thanked: 45 times
Post by FLXC90 »
+1 to what Jimmy says.
Wet vs dry compression test ( for science!)
Run some ATP AT-205 through your oil to re-invigorate your valve stem seals (and many others).
replace oil cap seal.
Current Volvos:
callahanoffroad
It's obviously volvoism, not volvology.
I knew this was a dark hole. But sometimes you gotta open it! :D
Thanks for the responses.
1L/1000km is an easy measurement to remember. Thanks Misha!
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Hocus Pocus. The car should not burn more than 1/2 quart every 3000 miles under normal conditions. The rest is just an excuse for something wrong. Every Volvo I have owned never burned more than 1/2 per oil change, one was at 190k miles. If the oil consumption is up then something is wrong or the engine is old and tired. At this point the question is what are you willing to accept.
My old BMW and Porsche at highway speeds a different story.
