Hi
I recently bought a 1995 850 with an alpine CD changer mounted on the glove box. Problem is I can't select the CD function on the head unit
Is this a common issue on this model ?
Please leave any suggestions
Thanks
850 CD changer won't work
- Has thanked: 2210 times
Have you checked the cable is fully home in the back of the head unit and the CD changer?
Not normally an issue. Does your head unit have a single CD changer built into it also?
Nico99
- Year and Model: 1995 850 GLT
- Has thanked: 3 times
Hi Neilscot850 wrote: 17 Apr 2018, 10:27 Have you checked the cable is fully home in the back of the head unit and the CD changer?
Yes I've doubled checked the cable and my head unit has a built-in cassette player
Nico
What model of Head unit have you got nico? SC-8XX?
Do you have an owners handbook for your car that describes that model of radio? If not I'll go look to see if I have one for an 850 in the box of manuals I have in the basement to see if there are any 'tricks' we should know about to getting it to work.
Did the car come with the CD multi-changer or did you retro-fit it? Should have asked what model the changer is as well. If it is a later unit than the original radio head unit it may not be compatible.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Is it possible the one installed (aftermarket?) operates as a tune-able FM station?
2023 Lexus RZ450e -66k
Nico99
Wize I don't think it's an aftermarket changer, it's a alpine changer mounted on the glove box connected directly to the head unit by wire and there are no signs of it being replaced .
Anyways I'll test the FM frequencies
Thanks
Thanks
Nico
- wizechatmgr
Yeah, eject all the discs and then listen for a quiet channel. If it is an aftermarket hooked up this way, you should have an FM channel with no noise, no hiss, nada while it is turned on.
If it is a factory radio, you will have DIN connectors running off of it (unless I'm mistaken...) similar to "ancient" keyboards
- 373 Views
Last post by TafferKing
- 20 Replies
- 3661 Views
- 806 Views
Last post by tryingbe
- 2202 Views
Last post by Tiny Tim 077
- 5344 Views
Last post by andregtable
