850 CD changer won't work
Nico99
Year and Model: 1995 850 GLT
Has thanked: 3 times
Post by Nico99 »
Hi
I recently bought a 1995 850 with an alpine CD changer mounted on the glove box. Problem is I can't select the CD function on the head unit
Is this a common issue on this model ?
Please leave any suggestions
Thanks
Nico
Has thanked: 1853 times
Been thanked: 1714 times
Have you checked the cable is fully home in the back of the head unit and the CD changer?
Not normally an issue. Does your head unit have a single CD changer built into it also?
Nico99
Post by Nico99 »
scot850 wrote: 17 Apr 2018, 10:27 Have you checked the cable is fully home in the back of the head unit and the CD changer?
Hi Neil
Yes I've doubled checked the cable and my head unit has a built-in cassette player
Nico
What model of Head unit have you got nico? SC-8XX?
Nico99
Post by Nico99 »
It's a Sc-801
Nico
Do you have an owners handbook for your car that describes that model of radio? If not I'll go look to see if I have one for an 850 in the box of manuals I have in the basement to see if there are any 'tricks' we should know about to getting it to work.
Did the car come with the CD multi-changer or did you retro-fit it? Should have asked what model the changer is as well. If it is a later unit than the original radio head unit it may not be compatible.
Nico99
Post by Nico99 »
I don't have any owner's manual, the previous owner lost them
The CD changer is original,and is loading and ejecting the CD deck, so there should be no problems.
Nico
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
Is it possible the one installed (aftermarket?) operates as a tune-able FM station?
Nico99
Post by Nico99 »
Wize I don't think it's an aftermarket changer, it's a alpine changer mounted on the glove box connected directly to the head unit by wire and there are no signs of it being replaced .
Anyways I'll test the FM frequencies
Thanks
Nico
wizechatmgr
Yeah, eject all the discs and then listen for a quiet channel. If it is an aftermarket hooked up this way, you should have an FM channel with no noise, no hiss, nada while it is turned on.
If it is a factory radio, you will have DIN connectors running off of it (unless I'm mistaken...) similar to "ancient" keyboards
