850 Timing Belt Replacement
banjoman
Year and Model: 850, 1996
Post by banjoman »
No doubt this is addressed on the site, but I could not locate it, so my apologies. My 1996 850 Wagon has 240k. The timing belt was replaced 7 years ago with 32,000 miles since. Should I replace it?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Yes. You're hitting the time limit, not the miles limit. It's 7 years/70k miles.
search.php?keywords=1996+850+timing+bel ... mit=Search
Also -> Amazon link
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Time is relevant...but with only 32k on the belt i would leave it for 2-3 more years...if that is my car.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 312 times
Been thanked: 818 times
If you do decide to replace it keep in mind that this would be an unusual timing belt service: you would only change the belt, because you were concerned the rubber is deteriorating.
A "normal" timing belt service would always replace the accompanying roller pulleys, and sometimes also the hydraulic tenisoner and water pump, etc.
Your climate (GA) is warm but doesn't see very extreme temp swings, so like misha says I might let it go another year or two if it was me. Definitely inspect the belt though, for cracks.
Has thanked: 1611 times
Been thanked: 4074 times
I would also run that 2-3 more years, but I am a risk taker.
I ran my 99 to 137k, 14 years
I’m running my New Beetle belt 15 years
