850 Sunroof Position Adjustment
NYC-Volvo
Year and Model: 850 R, 1996
Has thanked: 3 times
Post by NYC-Volvo »
Does anybody know how to adjust the position of the sunroof in the closed position? My sunroof leaks in heavy rain, and I noticed that, when closed, the glass roof is not flush with the cars roof. It seems to be a little lower, and when I tap the sunroof switch a few times, I can get the roof to close flush. Is there a "closed position" adjustment so I do not have to do this by hand?
Also, do you think it is good to change the seal at this time? I have a 1996 850 R with 150k miles.
1996 850 R
Previous Volvos:
1997 850 T5
2000 S80 T6
wickid54
Year and Model: '95 850 GLT
Post by wickid54 »
NYC-Volvo
Post by NYC-Volvo »
I posted my question question quite a while ago, and finally fixed it about two years ago.
Here's how I did it: (I am going by memory, no photos)
  • It's is very simple, adjust only 4 screws... from the inside of the car...
  • Locate and remove the plastic rail covers Decorative) on both sides
  • This reveals the screws, two on each side
  • Loosen the screws and position the sunroof where you would like it to be (there is only some, yet enough, leeway)
  • Tighten the screws
  • Replace the plastic rail covers
Hope this helps!
-Scott
1996 850 R
Previous Volvos:
1997 850 T5
2000 S80 T6
Has thanked: 1847 times
Been thanked: 1710 times
Late to the party, but I thought I read somewhere that there is a reset for setting the home position for the sunroof. May only be for later cars. I'll now have to try to find that.
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
I notice that my sunroof sits a bit higher above the roof compared to other Volvos I've seen. The sunroof motor is cooked and it doesn't leak as far as I know, so I kinda don't want to mess with it. But it doesn't look quite right the way it is now. Will keep this info in mind.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
Glass in closed position the front of glass is below roof and at rear of glass above body is normal. My moonroof in the last several cars came from the factory this way and the answer from Volvo is it is positioned this way to prevent wind noise. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
WhatAmIDoing
On mine the back is at the roof line, but the front is above. So the exact opposite of how it should be I guess.
