Just got lucky with the SRS Urgent caution.
hethaerto
Year and Model: 02 Volvo S60 T5
Been thanked: 3 times
Post by hethaerto »
My new Autel MD808 code scanner told me I had a bad SRS bulb in the gauge cluster.
Interwebs says this is caused by a weak solder joint in the cluster. Cheapest cluster repair is $150.
Decided to pull the cluster and prep it for shipment. Pulled the cluster, but decided to spray the socket and plug with Deoxit and see what happens. Plugged it all back up, connected the battery, fired it up, SRS caution still there. Plugged in the scanner, cleared the caution and it didn't come back.
$250 for the scanner, $150 saved just now.....
One more repair and this thing will have paid for itself.
What's funny is that the cluster had the name and address of a previous owner who likely had the same issue, had the cluster repaired, didn't clean the plugs, reinstalled, got the caution again, didn't have the right scanner to access the SRS module and finally said "Screw it".
8)
8)
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
hethaerto wrote: 20 Apr 2018, 11:57 My new Autel MD808 code scanner told me I had a bad SRS bulb in the gauge cluster.
8)
Write yourself a check for $150 PLUS shipping. !
hethaerto
Post by hethaerto »
:D
8)
