A month with a 850, all the issues so far
Nico99
Year and Model: 1995 850 GLT
Has thanked: 3 times
Post by Nico99 »
Hi
Its been a month since i bought a 850. The car has given me no serious problems at all. But there are 2 little details that been annoying me
When i roll the driver's window all the way down i get a strange clanking noise and the power antenna isnt working
Thanks
Nico
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
Nico99 wrote: 24 Apr 2018, 12:37 Hi
Thanks
I try to not roll the window all the way down. :lol: Power antenna not working is extremely common, mines up so I don't care. There are a couple threads detailing how to replace or rebuild the power antenna motor if you search.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
Most probably the rear window guide in the door is broken. Take the door panel off (good videos can be found on how to do that). Tgen check for loose parts inside the door. Replace if necessary.
1996 855 R,
2010 V70 D5,
sventastic
Year and Model: 1996 854R
Been thanked: 6 times
Post by sventastic »
I have the same clunk when rolling the window all the way down and have been told this part is the culprit
https://www.fcpeuro.com/products/saab-w ... tor-roller
1996 854R | M56H | 16T | 274k | BC, Canada
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
It seems to me I recall when the antenna went bad in I think the 1996 960 Volvo put a new mast in it. I had a couple power antennas go bad over the years. I was so happy when Volvo did away with them. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
Nico99
Post by Nico99 »
WhatAmIDoing wrote: 24 Apr 2018, 13:32
Thanks
Im trying not to do that but its tricky because of the auto switch
Nico
Nico99
Post by Nico99 »
Clemens wrote: 24 Apr 2018, 14:11 Most probably the rear window guide in the door is broken. Take the door panel off (good videos can be found on how to do that). Tgen check for loose parts inside the door. Replace if necessary.
Well now that ive taken out the door panel, I see youre right the guide is completely loose but not broken. Is there any way to fix it ?
Nico
Has thanked: 311 times
Been thanked: 817 times
Check the end of the guide where it attaches to the door - that is where they usually break. Even though it looks good it may be broken.
Has thanked: 2207 times
Been thanked: 1852 times
There should be a torx or phillips screw about halfway down the back edge of the door below the latch. If it is there, remove it and you will probably find the bracket that should hold the window rear guide has broken and falls into the bottom of the door. Later cars used a rivet to hold it in place. The 850 one may be obsolete but the later V/S 70 one works too.
