Purchase 01 XC70 AWD?
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 26 times
Post by greg850r »
I want to know what you think. The carfax shows T belt at 100,000 and it has 216,000 on it, so I figure it needs one right now. Car is on a little dealer's lot 2 1/2 hours away from me. Carfax shows 3 owners NY car (dealer serviced), then Chicago (dealer serviced) finally traded in by owner 3 (serviced at PepBoys) at a dealer in Illinois who sent it to auction, presumably over the miles. I know 850s pretty well inside and out now but this is not a model I have any experience with. Comments welcome, I need an education. For $2,300 if its a decent driver for my wife for the next 2 years, I got my money's worth.
https://www.burkeautoandatv.com/vehicle ... r-mo.shtml
thanks all, you're the best.
Greg
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
hethaerto
Year and Model: 02 Volvo S60 T5
Been thanked: 3 times
Post by hethaerto »
Buy it. First: drain the ATF and replace with Amsoil Signature Series ATF. Drive it a few weeks then do it again.
Amsoil ATF solved all my trans issues, the same issues that inspired other Volvo owners to replace their transmissions.
8)
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
An 01 xc is not the best choice to enter the P2 world, even more so given the number of owners and the distance to travel.
If the AWD is not a must (for winter 4 good winter tires are a much better choice imo), an S60 from 2004-2005 and up with less than 150k miles and no more than 2 owners would be a better choice. These cars can last perhaps more than a 850 but when they are neglected the story can change. At around 150k the repairs do pile up so the more the PO has done (with the correct brands) the better. Main points would be several suspension parts, PCV, AWD among others.
Been thanked: 4068 times
Greg...you need to drive it from a cold start to a hot highway run and the transmission has to be flawless.
If so, it’s a decent buy.
hethaerto
Post by hethaerto »
I drove my 02 XC70 for ten years, now my oldest daughter is driving it.
It needed a new fuel pump (recall), front hub bearings, and rear tail lamp housing assemblies. That's it.
8)
greg850r
Post by greg850r »
Things of note from the carfax:
03/25/2003
7,548 mi
Recommended maintenance performed
7,500 mile service performed
Engine/powertrain computer/module reprogrammed
Body computer/module checked
Engine/powertrain computer/module checked
01/06/2012
96,100 mi
Computer reprogrammed
Front brake pads replaced
07/19/2012
103,188 mi
Timing belt replaced
Drive belt(s) replaced
Sway bar link(s) replaced
These were all done by the 2nd owner at
Patrick Cadillac
Schaumburg, IL
855-688-3573
patrickcadillac.com
One more from 3rd owner done at PepBoys
03/26/2014
136,502 mi
Maintenance inspection completed
Oil and filter changed
Do you think any of these were about the software that caused trans problems with these?
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
Nothing of note there. Unless that’s Caddy dealer also had a Volvo franchise , there Is no way they would be doing warranty ECU reprogramming.
You HAVE to drive this thing to see if the trans is in good shape. The first generation 5 speeds had a bad neutral stop software feature that slammed them, so you need to assess that. They have their own special sticky thread for discussion.
Quoting Volvo expert Jim...”Don’t buy a 2001 unless it’s perfect” and “ keep an eye open for the rare heated third seat”
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
hethaerto wrote: 24 Apr 2018, 18:10 Buy it. First: drain the ATF and replace with Amsoil Signature Series ATF. Drive it a few weeks then do it again.
I would never use Amsoil ATF again in this transmission, it has waaay too low viscosity index. Idemitsu Type-TLS is the closest match, Toyota T-IV is OK too.
hethaerto
Post by hethaerto »
vtl wrote: 25 Apr 2018, 05:32
Amsoil sure makes my trans operate well.
8)
oragex
Post by oragex »
I always recommend this site. Keep in mind that the situation may differ, plus there are always owners who don't acknowledge all the faults. Also, the car in question has 210K miles on it, so expect to have plenty of things to fix, no necessarily all big items
http://www.carsurvey.org/reviews/volvo/xc70/
