parking brake cable - 2004 v70 - parts 9191484
babybluebug
Year and Model: 2004 v70
Post by babybluebug »
I am looking at overhauling the parking brake on a 2004 v70 including new e-brake shoes and the cables to the rear brakes. I was wondering if anyone has used ATE cables as opposed to volvo oem. Feedback appreciated!
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
babybluebug wrote: 27 Apr 2018, 12:50 I am looking at overhauling the parking brake on a 2004 v70 including new e-brake shoes and the cables to the rear brakes. I was wondering if anyone has used ATE cables as opposed to volvo oem. Feedback appreciated!
Oem are discontinued by Volvo .
Try IPD.
Has thanked: 1609 times
Been thanked: 4065 times
Added part number to thread. 9191484
FCP shows that part indefinitely back ordered
It also shows compatibility with P2 V70s but only 2003-4 XC70 s ?
jonesg
Post by jonesg »
One of the mvs sponsors sells the cables. Eeuroparts, link is at the top of the page.
I got all 3 cables.
Ebrake still sucks.
I ordered the threaded barrel adjusters for the shoes. Waiting to install.
Supposedly the adjusters make all the difference.
babybluebug
Where did you order the adjusters from? I was just going to order the cable to the left and right rear brake (2 identical cables). My goal is to pass Mass state inspection. Never use the e-brake!
jonesg
Post by jonesg »
babybluebug wrote: 28 Apr 2018, 18:23 Where did you order the adjusters from? I was just going to order the cable to the left and right rear brake (2 identical cables). My goal is to pass Mass state inspection. Never use the e-brake!
Yeh, I went thru that in MA last yr, so i moved to Maine, that'll teach em.!
Adjusters come as a complete kit with all the brake springs etc , IPD , I think it was $26 for both wheels plus $10 mail.
Mine is a 2004 v70.
From the invoice,
120935 - Parking Brake Hardware Kit - P2 S60 V70 XC70 XC90 S80
USD 26.95
jonesg
Post by jonesg »
Mine is a 2004 v70.
From the invoice,
USD 26.95
Adjuster kit.
Adjuster kit.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The adjusters help eliminate that 'delay' before the handbrake engages (the car still moves a few inches before the shoes can grab) when adjusted correctly through one of the rear drum holes. It also helps increase a little bit the 'bite' but nothing dramatic. What actually helps, is installing new cables.
But I found out that this doesn't last and it needs readjusted perhaps ever 6mths. It may also wear the shoes faster than without, because it basically keeps the shoes in a slight contact with the drum.
Btw grab the adjusters for free from the junk yard, every pre-2000 Volvo had them, such as S70, V70
jonesg
Post by jonesg »
Came across this video. He had to shorten the adjuster by cutting the end off.
Although IPD says it fits.
I'll take a look at mine later.
i never use my ebrake.
jonesg
Post by jonesg »
No need to cut the adjuster, fully retracted its the same as the solid bar spreader.
Within a whisker anyway. Measured.
