1999 V70 AWD P0236, P0237, P1113 codes persist after TCV, MAF replacement
deardeergod
Year and Model: 1999 V70 AWD
Post by deardeergod »
Last weekend I tried to tackle a few engine codes my car had. I ordered a new HD TCV from ipd, and a Bosch MAF. I unplugged the battery and installed the parts. The battery would have been disconnected for at least an hour.
Fired her up and the check engine light came back immediately. Checked the codes and those three codes were there. The car drove and felt the same as before (which was fine). I realized the wiring for the TCV and MAF stem off the same part of the wiring harness. Is there an internal connector for this part of the harness, or should I start looking for chafed wires? Any thoughts as I move forward with this would be appreciated.
Has thanked: 2215 times
Been thanked: 1853 times
I'd check the wiring, in particular the TCV. When I had work done at the dealer, the wiring harness magically broke apparently, but in their defense, the wires to the TCV from the connector where tired and broke,
When fitting the IPD TCV, I always tell folks NOT to screw the front 'leg' all the way in. If you do it will push the small metal mesh cover in there backward and prevent the valve operating or make it inconsistent. IPD tick me off as I asked them to warn customers to this issue as I managed to damage the issue. When I figured out the issue, they at least sent me a replacement but never update the install info. Turn the front pipe no more than 3-4 turns inward. It will feel loose but they claim that is ok.
