2006 V70 Base Oil Leak-- Front Cam Seals?
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I've got a significant oil leak on the front (timing cover) side of the engine. I have not removed the timing cover to check, but my suspicion is that the leak originates from the front cam seals which I believe are original to the car at 138K miles. Can I change front cam seals without pulling the timing belt? If it is indeed the fronts, then I will change the rears as well.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
E Showell wrote: 30 Apr 2018, 09:30 Can I change front cam seals without pulling the timing belt?
Hmm... It depends on whether the engine is running or not. If you are a licensed and certified Magician, then yes; even with the engine running :lol:
I would not remove the T-Belt completely. If it's relatively, new then just loosen the tensioner, take the belt off the cam sprockets, do the seals, and then put everything back including timing
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
regent
Post by regent »
The leak could be from failing o-rings in VVT hubs (probably you have that); you may want to have those ready along with the cam seals
2015 BMW 335i
E Showell
Post by E Showell »
I am 12K miles from a timing belt change at the prescribed interval of 150K miles (and theoretically 2 years overdue on time). I may just have my mechanic do the change. Water pump with a first new timing belt at 150K miles?
'95 855 auto (sold)
regent
Post by regent »
I would do the pump now for POM = Peace of Mind that is, otherwise it's with every other TB change. You would want to replace the TB idler and tensioner, also the serp. belt and its tensioner pulley for good measure
2015 BMW 335i
E Showell
Post by E Showell »
Yeah -- I usually do the whole nine yards with a TB -- Serp., tensioners, etc. That has been my usual practice. Aisin only for water pump as well.
'95 855 auto (sold)
dlundblad
Year and Model: 2002 S60 2.4t
Has thanked: 6 times
Been thanked: 4 times
Post by dlundblad »
If you can do the timing belt, you can do the cam seals.
You just need the cam holding tool. I'd also recommend a low profile (perhaps 3/8"?) T55 socket. I used a 1/2" and hardly had any room.
*** If you take it somewhere, go ahead and do the water pump now as labor will essentially be the same. If you DIY, you could easily wait an additional 30k or so.
Hers: Charcoal 2002 S60 2.4t 187k
E Showell
Post by E Showell »
I won't do a timing belt on my own. I've tried and don't have the hand strength to mount the thing. Additionally, the cost of failure is too high for me.
'95 855 auto (sold)
Been thanked: 504 times
Post by cn90 »
I wrote a DIY: 2005 Volvo XC90 2.5T Timing Belt, Water Pump, Serpentine Belt:
viewtopic.php?f=10&t=83521
You need a locking tool (and 2 plastic plugs for the REAR of engine, use only Volvo OEM plugs). Locking tool is $50-$60 on ebay.
The issue of VVT hub O-rings, sometimes it is easier and better to replace the entire hub ($250/each), but if you source the O-rings, then go for it. My guess is the usual seals and not the hub itself (BTW, use only Corteco or dealer seals).
If you go through the thread below and the photos I posted, then you will see the engineering aspect of the VVT hub...
Large oil leak after replacing exhaust camshaft (cvvt) seal - help needed!
https://volvoforums.com/forum/volvo-xc9 ... ded-81251/
Been thanked: 4065 times
How many miles are you putting on it each year Evan? If it’s something like 10k, leave the OEM pump in and run it for another 5 years, I’ve got thecam lock tool if you are up for it. I can give you a day on one of NJ trips
The belt is simple and not to be feared
