You may wish to chase all the head bolt holes with a tap and then blow them out with compressed air. Sometimes oil, coolant, small children, etc will get stuck in the bolt holes and your actual torque yield will be incorrect. One other thing I like to do is torque the bolts down in the afternoon, then torque them again the next morning while sober.
I'd also try a different torque wrench this time - or get your existing wrench calibrated - just in case it is the root cause of the evil.
2nd Head Gasket in 12 Months | Rant and Advice Wanted Please Topic is solved
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
- Has thanked: 311 times
- Been thanked: 817 times
I think he is a long way from pulling the head but if it comes to that, cleaning out the head bolt holes is not a "you may wish to ..." thing, it is a "and by all means do not forget to ..." thing.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
LOL, Most people love my rants.abscate wrote: 27 Mar 2018, 17:59 Make sure your dog is healthy before Robert comes.
Still one of my favourite videos on YouTube , Robert
“ Thst will not be a comfortable situation”
- nickelghandi
- Year and Model: 1998 Volvo S70 GLT
- Has thanked: 14 times
- Been thanked: 3 times
Lol to the small children and sobriety. Luckily, I do not need to pull the head on this one. I am going to be pulling the head on my 99 V70 (which I just found out is an XC with the shaft removed). I think it has a burnt exhaust valve. I will run a tap through the head bolt holes though. The V70 is sort of my practice car. Even though the engine configuration is slightly different, many of the jobs like head gasket require the same procedures to be followed. Hopefully I can use it to build my confidence for my blue S70 and end up with 2 decent running P80's.
-Nick
- rspi
Contact rspi..
You think it has a burnt valve?nickelghandi wrote: 03 May 2018, 14:09 Lol to the small children and sobriety. Luckily, I do not need to pull the head on this one. I am going to be pulling the head on my 99 V70 (which I just found out is an XC with the shaft removed). I think it has a burnt exhaust valve. I will run a tap through the head bolt holes though. The V70 is sort of my practice car. Even though the engine configuration is slightly different, many of the jobs like head gasket require the same procedures to be followed. Hopefully I can use it to build my confidence for my blue S70 and end up with 2 decent running P80's.
There is a V70 AWD model out there that is not XC.
- June
- Has thanked: 523 times
- Been thanked: 261 times
My 1998 V70 said Cross Country spelled out across the back bumper and V70 on the tailgate. Junerspi wrote: 04 May 2018, 13:48You think it has a burnt valve?nickelghandi wrote: 03 May 2018, 14:09 Lol to the small children and sobriety. Luckily, I do not need to pull the head on this one. I am going to be pulling the head on my 99 V70 (which I just found out is an XC with the shaft removed). I think it has a burnt exhaust valve. I will run a tap through the head bolt holes though. The V70 is sort of my practice car. Even though the engine configuration is slightly different, many of the jobs like head gasket require the same procedures to be followed. Hopefully I can use it to build my confidence for my blue S70 and end up with 2 decent running P80's.
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- nickelghandi
It has 0 compression on cylinder 1 and no signs of HG leaking. Unplugging the coil and/or the injector makes no difference. I think I am going to make a new thread for this topic though.
The rear bumper has been replaced according to the PO whose wife backed it into a utility pole, and the title for the vehicle says V70XC. I know the title doesn't necessarily mean that it is an XC, but it has the AWD hardware, the title indicates it is an XC, and it is a turbo.
I didn't think the other AWD V70 had a turbo. Is that correct?
-Nick
It seems like it doesn't really matter what model the car is. But for the record, all AWD P80 cars had a turbo.
- Has thanked: 2199 times
The V70 AWD was a turbo. Just a lowered V70XC.
- nickelghandi
Interesting. I will have to see if I can find anything else. I haven't even cleaned it out yet from the PO. The manual may tell me what it is or not. It really doesn't matter. It is an AWD turbo P80 volvo with a suspected burnt valve. I plan to order all necessary parts to remove and reinstall the head, pull the head and see what is going on, order more parts as necessary, replace and put back together.
I'm estimating the total cost to be $1200-1500 if I do it and much more if I have someone else do it.
The only thing I'm a little hazy on is getting all the timing just right when putting it all back together.
-Nick
