I’m trying to figure out why my passenger power seat is not working. It was, but hasn’t for about a year. Both 20 amp fuses under the secured fuse box are good and there’s power to that circuit at the box. What I’m seeing is that’s there’s no power at the harness connection under that seat. I’ve checked both at the box under the seat and through that wire bundle to the control mechanism on the side of the seat and neither appear to have power. Is there another harness between the seat and the fuse box? Or does anyone have any suggestions on what I could try next?
Thanks in advance for any information,
Paul
Passenger Power Seat not working Topic is solved
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Does either work?
Does it move at all in any direction?
- Year and Model: Many Volvos
- Been thanked: 76 times
Most of my problems have been with the switch and I can get it to work again with contact cleaner.
pb49415
- Year and Model: 1998 S70
Yes, the driver seat functions fine. Moves in all directions. I must have a busted wire somewhere. All I get is millivolts on at both the wire harness connection under the seat and at the other end at the controller on the seats side.
pb49415
All terminal pins look to be not corroded. I’m just getting millivolts at both ends of wire harness please refer to other reply on previous comment.Ozark Lee wrote: 06 May 2018, 16:42 Most of my problems have been with the switch and I can get it to work again with contact cleaner.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
If we’re talking about the same things,
those metal cans aren’t fuses, they’re
thermally tripped auto-resetting circuit
breakers. Have you tried swapping them?
pb49415
Actually I did not. I thought they were just fuses. I’ll give that a try. If I blow the good one, where can I purchase a new one? Do auto parts stores carry them or it a stealership item? I’ll need at least one on hand if that’s the case.BEJinFbk wrote: 07 May 2018, 01:54 If we’re talking about the same things,
Thanks!!!! I would have never thought that was what they were.
- Has thanked: 1611 times
- Been thanked: 4075 times
They self reset. Look for voltage on both sides of the pins on the circuit breaker.
I think I grabbed them off my parts car which had one power seat? Probably the same for passenger
pb49415
I did a continuity check already and both checked good. Both slots of each connection on fuse box test 12v across also. I have not yet pushed the breaker in halfway to test through that. Is that what your talking about or have I done the check your describing already?abscate wrote: 07 May 2018, 05:14 They self reset. Look for voltage on both sides of the pins on the circuit breaker.
The reset inside, once they cool off from overcorrect. It sounds like supply side is good, so you have to fault trace backwards from the known lack of 12V back to the circuit breakers.
Wiriing diagrams for these cars are free online, but we don't host here by legal agreement with Volvo
- 4609 Views
Last post by mikkowus
- 1413 Views
Last post by Joffwillson
- 1385 Views
Last post by ZeroAnkoku
- 682 Views
Last post by AylmerQc
- 2365 Views
Last post by EuroTrash45
