How do I get the 240 rear axle shafts back in, big hammer?
ducttapeandzipties
Year and Model: 1989 245DL
Post by ducttapeandzipties »
I pulled both axle shafts and replaced the bearings. They came out pretty easily with a slide hammer. I pressed on new bearings and replaced the seals. Now I can't get the darn things back in again. They go almost all the way, I only need about another 3/8" I tried using the flange and bolts to pull it in, and tried smacking it with a hammer. They pulled out fairly easy, and I was able to pull the cone shaped races out by hand.
How do I get them back in?
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
ducttapeandzipties wrote: 28 Apr 2018, 21:35How do I get them back in?
Never done one of these, but were there C-Clips on shaft's end? Meaning, one was suppose to remove rear-end's rear face.
If C-Clips have dropped off, you need to fetch them
ducttapeandzipties
Nope, no c clips, I have the diff cover off. The axle is kept in the vehicle by the press fit of the bearing and spacer, which is in turn held into the axle tube by the flange and bolts. Really it should have no trouble sliding in, it didn't take much at all to pull it with the silde hammer and it went*almost* all the way in pushing it by hand.
93Regina
Post by 93Regina »
ducttapeandzipties wrote: 30 Apr 2018, 18:05 Really it should have no trouble sliding in
Again, never seen it, but Spider Gears can move about
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Are you certain that the bearing races are correctly sized?
1988 Volvo 760 Turbo Wagon
ducttapeandzipties
I can see the end of the driver side shaft inside of the spider gear, so it is sliding into the spider gear fine. The only thing I can think is that the bearings are too wide. They only had one bearing in stock at autozone, I ordered the other one from fcperuo, I would surely hope one would be correct, but who knows?
Being that a slide hammer was needed to the the shafts out, wouldn't that mean I would need to put them in with some force?
*EDIT - I was mistaken about FCP, actually got both bearings from autozone"
lummert
Post by lummert »
Can you use the above mentioned slide hammer to install the axles?
ducttapeandzipties
lummert wrote: 08 May 2018, 09:01 Can you use the above mentioned slide hammer to install the axles?
I could. but I don't think it's necessary. I went to the junkyard today, pulled an axle and measured the ring and bearing. The axle pushed right back in by hand, no problem. The ring I have is about 5mm wider than the one on the junkyard axle. And guess how far away I am from seating this axle completely? 5mm. So somehow I have two rings that are too wide, even though I bought them from two different places. The bearings came with two rings per bearing, the one I didn't use is the narrow enough, but the diameter is far too big to fit inside of the seal, almost 7mm too big, so no way it would fit. I'm tempted to try and pull the rings off and turn them down on the lathe at the hackerspace.
Just for illustration, this is the old bearing and ring. It's the new ring that is too wide causing it to bottom out on the axle tube. :(
lummert
Post by lummert »
Maybe use the axles that you pulled at the junkyard.
93Regina
Post by 93Regina »
What bearing kit did you get?
National Bearings RA-338
