Key Doesn't Open Driver's Door
Wagon99
Year and Model: 2002 V70
Post by Wagon99 »
The key just turns the cylinder round and round. Doesn't engage the door lock. I took the panel off and see that the linkage to the lock cylinder was not attached, but couldn't figure out how to re-attach it. It's a small area mostly covered by the sheet metal of the door. Very hard to access.
Anyone know how to do this?
Thank you.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
Wagon99 wrote: 13 May 2018, 11:15 The key just turns the cylinder round and round. Doesn't engage the door lock. I took the panel off and see that the linkage to the lock cylinder was not attached, but couldn't figure out how to re-attach it. It's a small area mostly covered by the sheet metal of the door. Very hard to access.
Thank you.
Look at this, might be same as yours.
Wagon99
Post by Wagon99 »
Thanks, but I already saw that video. It's different on the '99 than the '02.
MDK
Year and Model: 2004 S60R
Been thanked: 42 times
Post by MDK »
Yeah .. hey there Jones g...my key cylinder on the driver's door needed to be replaced... I went to scrapyard and replaced the entire Assy for door ( S70 or v70 same cel central locking system...1key door and another for everything else...get key with lock from salvage just plug in ... no software involved
jonesg
Post by jonesg »
MDK wrote: 13 May 2018, 15:24 Yeah .. hey there Jones g...my key cylinder on the driver's door needed to be replaced... I went to scrapyard and replaced the entire Assy for door ( S70 or v70 same cel central locking system...1key door and another for everything else...get key with lock from salvage just plug in ... no software involved
A good junkyard is Disneyland for bros.!
Wagon99
Post by Wagon99 »
The cylinder is not the problem. The cylinder is fine. Problem is, the lock housing is not connected to the door lock.
jonesg
Post by jonesg »
Wagon99 wrote: 13 May 2018, 19:59
Have you unbolted the lock barrel and withdrawn it from the door?
Wagon99
Post by Wagon99 »
jonesg wrote: 13 May 2018, 23:08
No. Is that what's necessary?
jonesg
Post by jonesg »
Wagon99 wrote: 18 May 2018, 12:59
Remove the barrel, insert flat blade screwdriver in the door and see if you can operate the mechanism.
