Changed fuel pump 1998 volvo v70xc.
Brianscott
Year and Model: 1998 volvo v70xc
Post by Brianscott »
I changed my fuel pump and now theres no fuel at the rail. Before i changed it i would get some fuel at the rail and i couldnt hear the fuel pump come on at all. Now that i have changed it i hear the pump but there is jo fuel at the rail. Im lost at what to do. It would start sometimes with old pump but it gave out on me and i replaced it.
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
Did you reconnect the fuel lines properly? If you switch the two fuel lines you will not get pressure at the rail.
1996 855 R,
2010 V70 D5,
Brianscott
Yeah i put the lines on the correct ports. They arent long enough to not get them on the wrong ones on mine.
Brianscott
I used the aftermarket proparts pump assembly also. I spliced them as well
Clemens
Post by Clemens »
With Proparts you mean proparts sweden? The chinese super low quality brand? Alot of people had horrible experiences with their stuff. This sucks, especially on an awd.
1996 855 R,
2010 V70 D5,
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Clemens wrote: 16 May 2018, 01:18 With Proparts you mean proparts sweden? The chinese super low quality brand? Alot of people had horrible experiences with their stuff. This sucks, especially on an awd.
With a ProParts fuel pump assemmbly,one of MVS members had car which burnt in a flame,because of a fuel leak which caused by a crack on assembly.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Brianscott
Scary do you guys got any good brands suggestion or should i get oem
Brianscott
Maybe got a crap pump i think or they didnt put the pump correctly in the assembly
misha
Post by misha »
Stick to original used one from a junkyard...it is more reliable than new aftermarket from ProParts.
If you actually need a new one,stick with good known aftermarket brands like Hella,Delphi,Febi...etc.
Avoid a "never heard" brand for anything...even for vipers.
To avoid confusion....i'm talking about assembly.
For fuel pump...Walbro (if you have a luck to find original),Pierburg,Bosch(oem),Hella,Siemens or Meat & Doria(they have Bosch,Siemens or Pierburg inside the box).Whatever you get from those three brands in the box,they are oem quality.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
Brianscott wrote: 15 May 2018, 15:07 Yeah i put the lines on the correct ports. They arent long enough to not get them on the wrong ones on mine.
You maybe can't go wrong on the outside of the housing,but check if you connected feed line correctly INSIDE the housing.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
