Parts failure poll: P2 Volvos: V70/S60/XC70 from 2001-2007
This topic is in the MVS Volvo Repair Database » Failed Parts Poll for P2 Volvos
What has failed on your P2 Volvo: V70/S60/XC70 from 2001-2007?
abs module
62
1%
ac compressor
62
1%
alarm system
126
3%
alternator
86
2%
axle shafts
95
2%
blower motor
66
2%
brake cylinder position sensor
18
0%
brake master cylinder
22
1%
broken ignition lock
26
1%
cabin switches
30
1%
catalytic converter
30
1%
cem (central electronic module)
33
1%
center console cover
65
2%
center console cup holder
62
1%
climate control fan
29
1%
climate system (including software upgrades)
26
1%
control arm bushings
177
4%
delaminated shoe on the parking brake mechanism
54
1%
discolored roof trim strips
113
3%
door whether strip
56
1%
engine cooling fan
29
1%
etm (electronic throttle module)
85
2%
exhaust flex down pipe
20
0%
exhaust pipe hanger broken (rusted, etc)
91
2%
front strut mounts
161
4%
front struts
146
3%
front window mechanism, slider or switch
76
2%
fuel pump
66
2%
fuel door hinge
123
3%
fuel door latch (not hinge)
84
2%
fuel tank pressure sensor
16
0%
headlamp ballasts (volvo calls them "Control units")
13
0%
headlamp leaky seal
38
1%
ignition coils
115
3%
ignition key failure (key replacement, programming)
13
0%
immobilizer antenna (start prevented error)
15
0%
lower ball joints
104
2%
lower torque rod
48
1%
oil sump seals
20
0%
other cup holder
28
1%
oxygen sensors
66
2%
parking brake cable
26
1%
passenger airbag sensor
6
0%
pcv system
123
3%
premature lightbulb/bulb socket failures
119
3%
radiator leak
79
2%
radio display
34
1%
rear view mirror
59
1%
rear bearing housing ("Knuckle")
6
0%
rear latch mechanism
27
1%
rear main seal
19
0%
seat controls cover
15
0%
seat motor
5
0%
siren control module
86
2%
spring clip to hold head light bulb
9
0%
spring seats
48
1%
steering rack
31
1%
steering wheel
4
0%
steering wheel controls
3
0%
sway bar links
135
3%
the turbocharger (whole thing)
17
0%
tie rods
128
3%
transmission (including software upgrades)
100
2%
transmission mount
93
2%
turbo valve
21
0%
turn signals
45
1%
upper engine mount
215
5%
vacuum pump/vacuum switch
18
0%
vvt solenoid
37
1%
water pump
29
1%
wheel bearings
98
2%
yaw sensor (anti-skid service required)
18
0%
Total votes: 4248
Georgeandkira
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
I bought my 2002 from its original owner at 70,000 miles.
I owned it over 130,000 miles (nearly 9 years) and sold it with 198,600 miles.
Your survey is a tad vague.
An A/C clutch should be separate from "A/C compressor".
Axle boots should be separate from "Axle shafts".
My upstream O2 sensor went out, not "O2 sensors".
I know it's difficult to design an "error free" survey. Perhaps columns for "perceived" Common Maintenance vs. Broke Too Soon is in order?
Then you'd have to have a "Did you buy cheap parts?" column. Kira
Been thanked: 4065 times
Georgeandkira wrote: 10 Jun 2017, 12:14 I bought my 2002 from its original owner at 70,000 miles.
Hey - more Volvo people in the Hudson Valley!! Having a fest at my place near Albany tomorrow.
hu5ker555
Year and Model: 2008 S60, 2015 S60
Has thanked: 46 times
Been thanked: 18 times
Post by hu5ker555 »
2008 S60 2.5T 169K miles
Owner since 99k miles
Snapped lumbar support cable.
Various signal bulbs.
Brake pads.
AM radio often times doesn't work. FM is fine.
That is all. Really. This car is amazing.
Georgeandkira
Everything I listed was done by the P.O. except for the ignition lock cylinder. The Car Gods saved that one for me at 69,779 miles.
Struts and spring seats
Fuel pump
Fuel door hinge
Camshaft reset valve
One sway bar link
One tie rod end
One CV boot
Fuel pressure sensor
Front brake hoses
Upper engine mount
Rear exhaust bracket
An unspecified PCV hose
"Rear lamps" TWICE! (struck me as odd)
The P.O. went through 3 complete brake jobs (I consider that mere maintenance)
Also, I gotta love that the brake fluid was flushed twice and the transmission was "B&G flushed" at the dealership.
dlundblad
Year and Model: 2002 S60 2.4t
Has thanked: 6 times
Been thanked: 4 times
Post by dlundblad »
Didn't see the PNP switch mentioned.
She said it was like driving in 4th gear, hitting something and dropping down into 1st. A transmission service light came on too.
My code reader reset whatever it was mad about. The car drove fine for a few more months then it did it again. Reset the code and bought the part right after that. FCP Euro has them.
Hers: Charcoal 2002 S60 2.4t 187k
V70r carbon
Year and Model: 2005 v70r
Post by V70r carbon »
Hooo boy... 2005 V70R M6. In the last year and a half ( because I love the car ) 244K I've had to change.. Hood latch cable, parking brake cables, front link kits, head gasket, (includes head planning, valve stem seals, timing belt, serpentine belt, water pump, PCV, etc..)
AWD Haldex module with the pump, (XeModex) alternator, (why not?) replaced the Xenon lights to LED, (ballast for Xenon was more expensive), coolant tank and cap, front top plates for the shocks, and the turbo cooling pipe, (trombone), all four brake discs + pads, and the partridge in a pear tree. And just this week the lights went out for the FOUR-C (SUM) I really must love the car...
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
V70r carbon wrote: 18 May 2018, 21:51 Hooo boy... 2005 V70R M6. In the last year and a half ( because I love the car ) 244K I've had to change.. Hood latch cable, parking brake cables, front link kits, head gasket, (includes head planning, valve stem seals, timing belt, serpentine belt, water pump, PCV, etc..)
Yeah these cars do need such attention (unless they are left to degrade). On your list I'd say the only less common item is the head gasket but again, being an R which must have took some legal abuse it is to be expected at these miles - being a Canadian Car I expect 244K to be km?, even so this only shows how long lasting these cars are, 240k km is the average mileage of cars in the scrap yard.
The 4c shocks maybe it's just one of them? Or the module ? (xemodex)
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
244k km is barely broken in ;)
I'd never replace the xenons though. They're really awesome expecially with an extra 55 W xenon in the high beam socket. And I'd never pass inspection again if I did..
dono
Year and Model: 04 V70&XC70 2.5T AWD
Has thanked: 43 times
Been thanked: 6 times
Post by dono »
2004 V70 AWD T2.5 Wagon
230kmi
AC Compressor Clutch ('bread tab' repair working last 45k mi)
Struts at 180k
Ball Joints every 40k
Thermostat 180k
Brakes every 60-70k
Tie Rods 180k
Control Arms 130k
Upper motor Mount every 70k
Plugs every 100k
Fuel Pump 170k repaired by dealer under recall
Steering Rack leaking
***RADIATOR - failure of my radiator at 170k caused contamination of transmission with coolant! Take care of your radiators! I caught it soon enough that a new radiator and several flushes of transmission and cooling system fixed it - no known damage to the tranny now 60k mi later thank goodness.
Been a fantastic car still our primary family vehicle for local and long road trips!
2004 V70 AWD Wagon 2.5L L5 DOHC 20V TURBO 268k mi :D
2004 XC70 AWD Wagon 2.5L L5 DOHC 20V TURBO 155k mi :D
1999 Mercedes e320 4Matic 238k mi :D
2008 Toyota Avalon XL 165k mi (meh)
How about adding pump electronic module?
I’m beginning to think they last 10 years /125k on P2s
