ATF for power steering fluid
- Danonly55
- Year and Model: 1996 850 sedan
- Has thanked: 23 times
- Been thanked: 4 times
My owners Manuel says to use ATF for my power steering fluid. Is this a type "O" ?
2014 Ford 3.5L ecoboost XLT
1995 Volvo 850 wagon GLE
Life is tough, but it's tougher when your stupid'
" John Wayne
" John Wayne
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Yes...atf.It is Dexron II or III.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Not a typo-prior to 99 (I believe) they used ATF, check the owner's manual online for spec. Later models used power steering fluid (the green stuff) Don't mix the two.
Current Volvos:
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 73 times
ATF or regular PS fluid (Pentosin) works fine. Like FLXC90 said though, don't mix the two. Therefore, if you're not sure what's in there now and need to top up, I'd flush the whole system.
I've been using Mobil 1 Syn ATF in my PS system for about 8 years now.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- SuperHerman
- Been thanked: 207 times
What does your current fluid look like? Is it reddish to brown or greenish to brown? Both fluids will go towards brownish as they get dirty and old, but the base color is different. If reddish than you have ATF and if greenish then you have PS fluid. This assumes no prior incorrect service.
I think I read somewhere that some of the owner's manuals were incorrect so the suggestion to check on-line is smart as the proper fluid was updated in the on-line version.
- Danonly55
Thanks everybody for your input, My fluid is a reddish brown so I will top off with ATF. The flush will have to wait until next month.
" John Wayne
" John Wayne
- Has thanked: 292 times
- Been thanked: 765 times
Me too! In all of my P80 cars.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Has thanked: 1502 times
- Been thanked: 3813 times
I’ve used ATF , generic PS fluid, and finally Pentosin in my 1999, to reduce the count of fleet PS fluid bottles
- misha
You don't need to flush power steering system.
All you need to do is to remove old atf from a tank with a big syringe and put in a new atf fluid.
1 liter is enough,do not overfill.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Danonly55
Thanks Misha, I like that idea better but what about the lines and rack system there should be a fair amount of fluid in those areas?
" John Wayne
" John Wayne
- 13 Replies
- 7052 Views
Last post by GlennG2759
- 3743 Views
Last post by amblerman
