'95 850 No power
Hello all, I recently bought my first Volvo. It's a 1995 850 turbo sedan and I'm having a hard time figuring this out. It will run and rev fine in park and neutral, but won't have any power when I give it more than like 1/10th throttle. It's showing boost on the gauge, it has a new fuel pump and filter, and new cat. I've heard it could be the old cat blew out and clogged the muffler, it might have low fuel pressure, and the wastegate might have a problem. It sounds great when it's just idling or in park, but won't accelerate above thirty mph on its own. Any help or tips on where to start would be amazing. Thank you in advance.
- Been thanked: 4071 times
I takes about 1/2 HP to rev an engine and make it sound fine.
Extracting the 200 HP you need to get your car and up and going is a different beast.
test your fuel pressure at the rail on start and revving
New cap rotor plugs wires coil?
compression test is final answer.
Oh yeah -if you get boost when you rev at idle, something is wrong. How much are you seeing - or are you using the gauge installed by marketing ??
It's showing boost when driving, I'm thinking now that it's the tps. I don't know if the last owner replaced any ignition parts. I'm going to be testing the fuel pressure later, if I can scan it and the tps isn't working how it should
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You need 43.5psi at first prime before starting the engine.
At idle you must have around 35psi.
And again...at full throttle at high rpm you need 43.5psi.
19psi is too low even at idle.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
What brand is fuel pump?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
where was the pump purchased? vendor x price may reveal brand. otherwise it would be on the side of the pump motor (in the tank)
you should have access to the pump via an inside access panel.
Current Volvos:
- 9 Replies
- 3039 Views
Last post by mika
- 1346 Views
Last post by 1337
- 4170 Views
Last post by jonesg
- 1333 Views
Last post by StupidS80
- 1958 Views
Last post by SuperHerman
