Don't worry about it...i did the same long time ago.
Atf fluid for power steering doesn't have a service or time interval.
Volvo doesn't even recommend to replace it or flush it, just to top up when needed.
Only important thing for power steering pump is not to run on dry....to be left without oil.That's the only case in which it will be ruined.
ATF for power steering fluid
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Danonly55
- Year and Model: 1996 850 sedan
- Has thanked: 23 times
- Been thanked: 4 times
Upon a second look the fluid is more of a clear in color, I am assuming this is power steering fluid??
2014 Ford 3.5L ecoboost XLT
1995 Volvo 850 wagon GLE
Life is tough, but it's tougher when your stupid'
" John Wayne
" John Wayne
- misha
It MUST be red.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- SuperHerman
- Been thanked: 207 times
Post a picture of the fluid on the stick and wiped (dabbed) on to a white piece of paper or napkin.
- Danonly55
check original post for pic pleaseSuperHerman wrote: 21 May 2018, 10:42 Post a picture of the fluid on the stick and wiped (dabbed) on to a white piece of paper or napkin.
" John Wayne
" John Wayne
- Has thanked: 1611 times
- Been thanked: 4073 times
Pic didn't post, or Photobucket has struck again..
- Danonly55
ok pic now upDanonly55 wrote: 21 May 2018, 12:52check original post for pic pleaseSuperHerman wrote: 21 May 2018, 10:42 Post a picture of the fluid on the stick and wiped (dabbed) on to a white piece of paper or napkin.
" John Wayne
" John Wayne
- SuperHerman
Power steering fluid - I would use Pentosin CF 11 or 202. You should have enough to top off now and do a flush later.
- Danonly55
I would like to know if I can change over to ATF if I do the turkey baster method 3 or four times ??
" John Wayne
" John Wayne
- 13 Replies
- 7805 Views
Last post by GlennG2759
- 4447 Views
Last post by amblerman
- 553 Views
Last post by subzerocarfanatic
- 11 Replies
- 11830 Views
Last post by STSCowboy
- 30 Replies
- 27404 Views
